    [Solved]Speed dials changing colors
    77
    78589
      opera://flags/
      #force-color-profile
      scRGB linear
      This method does not work. None of these works. Speed Dial icons are still terribly miscolored.
        bbildman last edited by
        And while they are working on fixing the color issue with Spee Dial icons, I sure as heck wish they would get rid of the atrocious purple private page colors.
          leocg Moderator Volunteer @bbildman last edited by
          @bbildman It should be available in main window.
            B 1 Reply Last reply
          • kmielczarczyk
            kmielczarczyk Opera last edited by
            Fix for this issue is waiting for the release.
              N ? ? 3 Replies Last reply
              nick-cherez @kmielczarczyk last edited by
              @kmielczarczyk When? next year?
                nick-cherez last edited by
                So. I installed Opera 63 and disabled Update in opera://flags! 🖕🏼
                  A Former User @kmielczarczyk last edited by
                  @kmielczarczyk
                  I do hope so.
                  These colours are awful.
                  Look forward to the update.
                  Thank you.
                    leocg Moderator Volunteer @nick-cherez last edited by
                    @nick-cherez What is the option to disable updates in opera://flags?
                      N 1 Reply Last reply
                      bbildman @leocg last edited by
                      @leocg said in Speed dials changing colors:
                      Leo, not sure I understand your message, can you expand??
                        nick-cherez @leocg last edited by
                        1. Disable Internet
                        2. Uninstall Opera 64 and Install Opera 63
                        3. Delete file opera_ autoupdate.exe
                        4. Insert line "127.0.0.1 autoupdate.opera.com" in to localhost
                        5. Go to the "Task Scheduler Library" folder. Delete a task "Opera scheduled Autoupdate".
                        6. restart PC and enable internet
                          done
                          @bbildman I think the private window theme should also be available to be used in main window.
                            @nick-cherez And what about opera://flags?
                              it's was in old version. sorry
                                I changed mine via the heart symbol. Mine was a purple Facebook. So went to the Facebook page and clicked on the heart. There was the option to change it to what I want. The one I really want, even thought it shows blue in the red heart, it comes back as purple.
                                  Same problem here, after relaunching a dozen of times, colors are back.
                                  But spending 10 minutes just to launch opera, what tf?
                                    m.kaya last edited by leocg
                                    same problem here on v 64.0.3417.47 is there any solution for this bug?
                                      Strange that you noticed this bug just now. This bug was there far before the reborn3 announcement (O60). I'm still on O58 and also have this bug, In overall this bug is ~ 1 year old. There were many reports during this period in both blog and forum. I also checked the latest version (64.0.3417.54 Portable) and bug is still there, youtube's tile is
                                      'turquoise' sometimes instead of 'red'.
                                        A Former User @andrew84 last edited by A Former User
                                        @andrew84 Yes its a really old bug but no one knows if they will fix it. Maybe it is not an annoyance for the Opera Team like it is for the users?
                                          @kmielczarczyk
                                          What time is this coming? It cannot come fast enough. I have beer in the fridge for this event, and I would like to drink this special beer.
                                            Now with 64.0.3417.54 it's worse instead of better. Until now the speed dials were off-color on the first launch of Opera after a w10 reboot, but a relaunch of Opera cured it. Now the dials are off-color on all launches and with any flag set.
                                            Nice work Opera!!
