    [Solved]Speed dials changing colors
    77
    78589
      vr51 @Guest last edited by
      @nomansland I only stepped on finding a solution to this today because all my Speed Dial bookmarks had turned to purple after the Opera Stable update installed into my computer, and some shades of purple give me a headache.
      Seems that the colours change each time Opera updates; almost as though the scheme resets. There must be a cache that is automatically wiped after Opera updates are applied. If there is a cache it would suggest we might be able to manually edit those button colours.
        A Former User @vr51 last edited by
        @vr51 said in Speed dials changing colors:
        You're 100% right. That would be the best. We can choose the graphics in tiles, and we are not able to change the color...
        These purples are pretty nasty. 😠
          V 1 Reply Last reply
          @nomansland good to know we all are seeing the same colours. It means the Opera devs are setting them with each update.
            jmc5221 last edited by
            can confirm this, in previous version (I forgot the number) when speed dial change color I just restart Opera and the color back to normal, now in new version (Version:64.0.3417.47) I can not restore the color back to normal, even though I restarted many times
            Reply Quote 3
              Mixbox99 last edited by
              Same issue here. With Opera 64.0.3417.47 thumbnails' colors are incorrect. What used to be orange changed to purple, what used to be blue change to orange... Restarting Opera doesn't help.
                So now I have version 64.0.3417.54 and the color problem is still there.
                  nick-cherez last edited by
                  and me 😞
                    nick-cherez @bunjoman last edited by
                    @bunjoman said in Speed dials changing colors:
                    I've found a work around that works (so far) for me. I'm on Opera 63 and if you type "opera:flags" in the address bar you get access to some experimental settings (no guarantees!). Find the #force-color-profile setting and change it to sRGB (very rich colours on my kit) or Display P3 D65 (a more muted colour scheme). HDR settings might have some unexpected effects.
                    Hurrah! Success! 🙂 But i'm turned on "scRGB linear"
                      Same here, how can i fix it?
                        N 1 Reply Last reply
                        nick-cherez @Guest last edited by
                        @gurcellonline said in Speed dials changing colors:
                        go to "opera:flags"
                        find #force-color-profile
                        set scRGB linear
                          A Former User @nick-cherez last edited by
                          @nick-cherez Thank you so much 😃 It works
                            @gurcellonline 👍 🤝 😄
                              landspeed last edited by
                              Same problem here after updating to latest version. Would be nice to be able to set thumbnail colour instead of letting colourblind developers do their stuff.
                              Changing the color settings in opera://flags/#force-color-profile doesn't do anything
                                bbildman last edited by bbildman
                                Changing to sRGB didn't work in O64, nor did scRGB linear
                                  N ? 2 Replies Last reply
                                  nick-cherez @bbildman last edited by
                                  @bbildman said in Speed dials changing colors:
                                  Oh really?
                                    A Former User @bbildman last edited by
                                    @bbildman try set default and close than reopen opera yourself.
                                      B 1 Reply Last reply
                                      bbildman @Guest last edited by
                                      @gurcellonline Did that, did scRGB linear, relaunch and then sRGB. None of those worked. O63 seemed to hold the line (colors good), now with O64 back to bad colors
                                        Now back to Default, and colors are good, close and open manually without relaunch
                                          nick-cherez last edited by leocg
                                          Aaaahhhhhhhhhhhhhhh!!!!!!!!!!!!!!!😨
                                            Speed dial thumbnails, 9/10 times when starting Opera, Speed Dial colors are either washed out, or brightly colored Neon. It takes multiple restarts just to get the Speed dial icons colors to look Normal again. This was never an issue in the older versions. No matter which GPU, AMD, Nvidia, Intel. Its the same. I am sick and tired of having to constantly restart Opera just to get the Speed Dial Icon Colors to look
                                            acceptable.
                                            I have tried turning GPU Acceleration On/Off and it does nothing. I have updated drivers, tried on various GPUs. Its a problem with Opera. Its the only browser that discolors thumbnails.
