    Opera updated to 49 and now having flash player problems
    106
    112337
      lot3rd1 @leocg last edited by
      @leocg
        bbildman last edited by
        O48 had 4 options to work with:💯
        Now we have only::
        So much easier to have a global option to allow ALL sites to run Flash. It's obvious SOME sites have not adopted the "click to play flash" yet, as some work this way, and other simply won't play any flash.
          'Click to play' was removed probably due to the changes in Chromium. Now the options for Flash are those two only.
            Here's a web site that worked perfectly (the video window) but since yesterday when O49 updated isn't functional::
            http://www.livenewson.com/american/msnbc.html
            Works perfectly in IE11
              leocg Moderator Volunteer @bbildman last edited by
              @bbildman Same on Chrome here. It works if added to exception list.
                B 1 Reply Last reply
                I'm having a similar problem as well after the update. My Adobe Flash Player is up to date (currently 27.0.0.183 PPAPI) and it seems like adding certain sites to the flash exception list in settings (specifically Amazon and Hulu) still does not allow video to play. Adding other sites to the exception list (such as the addresses listed earlier in this thread) does allow video to play.
                  slytheringirl last edited by
                  I'm having the same problem after updating to Opera 49. Allowing exceptions doesn't work at all for me.
                  • O
                    operaturbosucks last edited by
                    Opera Turbo enabled every time Opera updates. Flash will not work with Opera Turbo. I absolutely hate that it turns itself on.
                      bbildman @leocg last edited by
                      @leocg
                      Ah, ok, I see that. And now it surely works. SO it seems that if we have a Web site that isn't allowing Flash and still doesn't display the "Allow" drop down, you can just add the website to the exceptions list under Flash settings
                        lot3rd1 last edited by
                        just adding the site to the exceptions list does not always work. I was doing that yesterday and it is not working when I add some sites to that list. I am not sure what the opera turbo is, but is definitely is not showing as any option when I click on the O in the upper left corner of my browser.
                        I had also contacted Adobe about this issue and they were doing quite a lot to try to get the issue resolved for me and in the end it was decided that this is browser behaviour, and not Flash Player, and it was recommend that I contact Opera for assistance.
                        Did that as well, but Opera certainly has not been of any help at all. At this point, I am going to start looking for another browser or just go back to using Google Chrome or Firefox and just dump Opera! If I could figure out how to go back to version 48.0 without loosing all of my settings, bookmarks and speed dials I would at least do that, but I can't find any information on how to do that either.
                          Chrome and any other Chromium based browsers based on the most recent version will behave the same. Other browsers like Firefox will probably start doing the same sooner or later.
                          Flash is in its ending process, so sites should start adapting to it.
                            leocg Moderator Volunteer @operaturbosucks last edited by
                            @operaturbosucks Unless you have enabled it by yourself, Turbo will not enable itself on start up.
                            You can check if Turbo is enabled on settings page.
                              @leocg
                              So, soon there will be no Flash for any browser, and how sites work will be up to each site to "redraw" their coding so as to work without Flash.
                              https://www.theverge.com/2017/7/25/16026236/adobe-flash-end-of-support-2020
                              https://redmondmag.com/articles/2017/07/25/adobe-ending-flash-support.aspx
                                @bbildman That's it. And I hope that those sites that use Flash start moving to a more modern solution (HTML5?) soon and don't leave it for the last hour.
                                  A Former User @lot3rd1 last edited by
                                  I'm also having trouble playing flash videos since i updated earlier today. Luckily adding exceptions manually has worked so far although it's annoying.
                                    Opera doesn't show me popup and allowing vk.com in settings doesn't work either.
                                    Opera, don't make me delete you.
                                      @ripperfrvr That site uses Flash?
                                        @leocg yes, for playing music
                                        vk.com/music
                                          @ripperfrvr
                                            Updated to Opera 49.0.2725.39 today and still no flash.
