    Opera updated to 49 and now having flash player problems
    106
    112204
      maxonnxc @burnout426 last edited by
      @burnout426 there is only 1 version in that folder
        maxonnxc last edited by maxonnxc
        @burnout426 said in Opera updated to 49 and now having flash player problems:
        Profile:
        "C:\Users\yourusername\AppData\Roaming\Opera Software\Opera Stable"
        Cache:
        "C:\Users\yourusername\AppData\Local\Opera Software\Opera Stable"
        i dont see either one of these 2 folder "profile or cache folder"
          burnout426 Volunteer @maxonnxc last edited by
          @maxonnxc said in Opera updated to 49 and now having flash player problems:
          Cool. Then that's the folder you mess with.
            The Opera Stable folder you're in IS the profile folder. The cache folder is at the same path in the local appdata folder.
              jjthebeerman last edited by
              I just uninstalled Opera 49, but did not delete opera data. Then installed Opera 48, but did it while I was offline (airplane mode). Then deleted the auto-update file in the program folder, then used WIN logo+R and ran taskschd.msc, then deleted opera autoupdate task. All of this while offline (airplane mode).
                For Opera 49, you can try this extension to see if it fixes Flash.
