    Huge problem after update today, white blank screen
    15024
      ngocevski last edited by
      Well this is unexpected. I just updated the browser this morning only to come back like this:
      https://ibb.co/LXrscfXR
      I can see that I can navigate through the sites by pressing my hotkeys and I can open the menu by pressing alt on the keyboard but once I click on update or settings the screen stays the same. Completely white and blank.
      I downloaded again Opera and reinstalled it, same thing.
      Very frustrating.
      I went on the ftp archive and got Opera_122.0.5643.92_Setup_x64 and reinstalled it, works perfectly
      Anybody knows what the issue is?
        N K leocg 3 Replies Last reply
        ngocevski @ngocevski last edited by
        OK I found the problem.
        After I reverted to the 122 version, I changed the angle flag from OPENGL to DRD11 and now it works fine in the updated version.
          B 1 Reply Last reply
          And another note, after 30 minutes of working on Opera I just realized why I had switched to OPENGL instead of the DRD11.
          OPENGL is much more smooth and better, DRD11 lags quite a bit.
          Hope this will be addressed in the next update?
            KotTHECat @ngocevski last edited by
            @ngocevski said in Huge problem after update today, white blank screen:
            Yes, same here.
            Its the file called Local State located in "..\AppData\Roaming\Opera Software\Opera Stable" causing this issue. If you delete it, Opera starts normally but all the tabs (and who knows what else) disappear...
            For me its not the solution, so i am sticking to the Opera_122.0.5643.142 for now...
            Hope this will be fixed soon.
              KotTHECat last edited by
              Just tried Opera Developer, and they havent fixed it in ver. 124...
                leocg Moderator Volunteer @ngocevski last edited by
                @ngocevski Opera One, Opera GX or Opera Air?
                  N 1 Reply Last reply
                  ngocevski @leocg last edited by
                  @leocg
                  Opera One.
                  The last version where the OPENGL config works perfectly is 122.0.5643.92
                  The 2 versions after that have the same problem
                  • Referenced by  alobpreis alobpreis
                    bbildman @ngocevski last edited by bbildman
                    Ok, I did that, and Opera One installed correctly. Couple things:; A few of my Speed Dial icons that have multiple links in them have empty images in the icon, and the other question, after you installed O 123, have you tried setting the Angle flag back to OPENGL?? (I tried setting the ANGLE back to OPENGL and the same grey screen reappears, making Opera in operable. I will just wait until the next iteration
                    Here's an image of one of them
                      K 1 Reply Last reply
                      KotTHECat @bbildman last edited by
                      @bbildman said in Huge problem after update today, white blank screen:
                      You also can modify the config file:
                      -Close Opera
                      -Open "Local State" with text editor
                      -Find string "use-angle@1" and change it to "use-angle@0"
                      -Save it and start Opera
                        bbildman @KotTHECat last edited by
                        @KotTHECat said in Huge problem after update today, white blank screen:
                        -Close Opera
                        I think I will wait for the next update, instead of trying to correct it myself. O 122 works just fine for now
                          @bbildman i recently tried Opera Developer v124 and there is no fix there...
                            Let's hope
                              I am using the version 122 with OPENGL because the versions 123 and 124 won't work with OPENGL and they lag too much under DRD11
                              So waiting on an update. I have to reinstall the 122 version every time I close Opera as it runs the update by itself every time
                                @ngocevski rename or delete "opera_autoupdate.exe" in "C:\Program Files\Opera\autoupdate"
                                  ngocevski @KotTHECat last edited by
                                  autoupdate
                                  Thank you
                                  • Referenced by  A andrew84
                                    NicotineLL 0 last edited by
                                    Same issue here with 123 update!
                                    A work around for now is to downgrade to 122 (you can find that here https://get.opera.com/ftp/pub/opera/desktop/122.0.5643.92/). For Windows you want Opera_122.0.5643.92_Setup.exe and just run the exe. After installation immediately close the browser and go to your opera installation folder and rename opera_autoupdate.exe as @KotTHECat suggested.
                                    Waiting for future update that fixes this. Huge F up!
                                      No fix for the moment, any way to know when it will be fixed?
                                        @ngocevski Already tried https://forums.opera.com/topic/87088/how-to-fix-opera-gx-grey-black-white-empty-screen-on-startup/?
                                          @leocg I am using version 122 with OPENGL for the moment waiting for the fix in the latest versions.
                                          If I change to DRD11 the latest version works but lags way too much
                                            Problem is fixed in the newest version. Thank you!
