    Updated Opera and VPN still doesn't work
    Opera for computers
    47
    103
    92092
      It does not work for me either before the update or after.((((
      • n8ph8ts
        n8ph8ts @sgunhouse last edited by
        @sgunhouse I updated to the new version and that's when i got the problem.
          Thank you for your help, VPN is working again 🙂
            A Former User @n8ph8ts last edited by
            @n8ph8ts What is the full version of Opera you have installed at the moment?
            You can view the version of Opera at the internal address:
            opera://about/
              biaxidentvic @sgunhouse last edited by
              @sgunhouse Awesome. Thx a ton, update worked for me. CHEERS.
                I had the same problem. I installed Opera developer version (silver colored opera logo)and now problem is solved. Now VPN is working on both stable and developer versions.
                  @247vpn Yes, because there was an update for the Developer channel in which the VPN problem was fixed
                  https://blogs.opera.com/desktop/2019/04/opera-61-0-3296-0-developer-update/
                  • n8ph8ts
                    @sgunhouse Been trying all day,eventually updated again,as of 5min ago started working,will keep you posted.
                      @n8ph8ts I got VPN working but updating Opera crashed both of my computers and I lost all extensions. Even a computer restore didn't work and it took me three hours to get my computers up and running again..
                        When is Opera going to fix the VPN issue, it has not been working for days.
                          https://blogs.opera.com/desktop/2019/04/opera-58-0-3135-132-and-60-0-3255-59-stable-update/
                          Did you update Opera?
                            ramai last edited by
                            Hi
                            I have information that vpn does not work (the vpn network is temporarily unavailable), almost one week!!!
                            this problem i have on the:
                            opera-beta 60.0.3255.57 - win10x64
                            opera-beta 60.0.3255.57 - linux debian buster/sid
                            only I have this problem?
                            thx
                            Rafal
                              Many have the same problems looking at the forum.
                                R 1 Reply Last reply
                                ramai @Guest last edited by
                                @iraja
                                hi, after actualization 60.0.3255.60 - VPN works!!
                                thx
                                Rafal
                                  @unionjack After upgrading my issue is resolved.
                                    The VPN service in the OPERA browser says it is broken.!
                                    Is this resolvable? The reason I chose OPERA over all the other browsers is that this was a feature.
                                      Make sure you have the latest version (60.0.3255.59 for Stable). If necessary (if it claims it is up to date but is not that version) go to the download page on opera.com and download it from there.
                                      • O
                                        operafanuk @operafanuk last edited by
                                        @operafanuk If any user still having problems with update and/or VPN not starting after update, please try this.
                                        All update streams [for me] working properly as above, BUT, I had to do following procedure on beta a couple of days ago
                                        1. Goto >O-Menu >Settings >Privacy and Security
                                        2. Goto VPN setting and toggle it off
                                        3. Restart
                                        4. Goto >O-Menu and update from >Help >About Opera or from >Update & Recovery
                                        5. If successful restart, if not, try a few times
                                        6. Goto settings and enable VPN and adjust your preferences
                                        7. Restart and everything should be as expected.
                                          Ballarat-Bill @leocg last edited by
                                          @leocg I have been getting this message, and it also says Opera is working to resolve this issue soon.
                                          it has now been 5 days like this...
                                          any ideas for a fix?
                                            leocg Moderator Volunteer @Ballarat-Bill last edited by
                                            Do you have the latest version?
