    Updated Opera and VPN still doesn't work
    Opera for computers
    47
    103
    93875
      @janwalker42 try manual update from here https://blogs.opera.com/desktop/2019/04/opera-58-0-3135-132-and-60-0-3255-59-stable-update/
        ? 2 Replies Last reply
        So the update available (and still didn't work) is only for stable version? What about for beta version users?
          ? leocg 2 Replies Last reply
          @adhikafuad Turns out I was on the beta version, so I downloaded the stable version and it works now (3255-59)
            @jeezara That worked, thanks. Turns out I was on the beta version, which seems to have been way out of date.
              @jeezara That worked, thanks. Turns out I was on the beta version, which seems to have been way out of date. I'm now on 3255.59 and it's fine.
                See https://blogs.opera.com/desktop/2019/04/opera-58-0-3135-132-and-60-0-3255-59-stable-update/#comment-4433548661
                  @leocg Brilliant, thanks!
                    Hello,
                    my VPN still doesn't work since Saturday. I tried a lot, I updated Opera, clean the cache etc. Can anyone help?
                    • G
                      GreedyOne last edited by
                      ı cant use vpn first ı try turn on vpn its color turn on blue and after few seconds its turn yellow it's we cant connect vpn at the moment ı cant solve this problem any one know how ı fix that bug
                        @tammy090 @GreedyOne Read through the thread please. A solution has been posted multiple times. Please note that even with the update, it takes time for the certificates to take effect (apparently).
                          I can't update my browser. I always got this (in German): Ihre Version: 60.0.3255.56
                          Beim Prüfen auf Updates ist ein Fehler aufgetreten
                          Zuletzt geprüft am Dienstag, 23. April 2019 22:07
                            ? R 2 Replies Last reply
                            riceuten last edited by
                            I had all the same problems as everyone here, and I updated (twice) to versions 56 & 57 from version 55. But I needed version 59. So I actually googled Opera 60.0.3255.59 and it showed me a link
                            https://get.geo.opera.com/pub/opera/desktop/60.0.3255.59
                            of which I clicked the bottom one. This relaunched my Browser, which STILL didn't work, but the Red O at the top right asked me to relaunch the Browser AGAIN and this time it updated to Version 60.0.3255.59. Which presently seems to work with the VPN.
                            It is all to do with an outdated http certificate for the VPN, apparently.
                              @tammy090 https://blogs.opera.com/desktop/2019/04/opera-58-0-3135-132-and-60-0-3255-59-stable-update/
                              This link goes to a manual update. You'll have to choose the version applicable to you, and allow it to update. That will bring you to their latest stable version.
                                riceuten @Guest last edited by
                                @tammy090 Manually update it. Google the Opera version (60.0.3255.59) and click on the bottom link of the "Get Opera" address
                                  Same here no VPN. Also the update crashed two of my computers.
                                  • O
                                    operafanuk @operafanuk last edited by operafanuk
                                    @operafanuk Okay, I managed to update my systems to Stable 60....59.
                                    It took many attempts on my Win10 64-bit system. Nevertheless, I still needed to uninstall the previous version many times over, and click Re-install before it would update.
                                    As has been mentioned on here, the .59 update for Stable wasn't working for everyone. So whilst I've now got it, I have noticed performance deterioration with this browser update, which I guess may be solved with the next update. I always say things happen which at times can't be helped - that's life.
                                    My Windows7 32-bit system was something else entirely and has taken me many hours to address.
                                    Try as I did - every which way - It point blank refused to update and was crashing the browser at around 43%.
                                    I eventually gave up with it, backed up my speeddials, then completely uninstalled it with IObit uninstaller.
                                    Downloaded a brand new totally clean Stable which gave me v60...59. Again, the performance is none too good just now, and I'm certain all this will be resolved with the next update.
                                    Thank you to Opera devs for pushing the update out on a Sunday. We all appreciate your time and efforts.
                                      O 1 Reply Last reply
                                    • n8ph8ts
                                      n8ph8ts last edited by
                                      My VPN been down for 3 days now,is there a chance it's coming back any time soon??,or have we lost it all together.
                                        Hi All,
                                        As most of the previous topics are locked , I am creating new one.
                                        My VPN keeps on disconnecting. Before the upgrade it use to work fine. Currently, I am using version: 60.0.3255.27.
                                        No proxy is used.
                                          Update to the current version (60.0.3255.59). Some people report having to manually update.
                                              n8ph8ts B 3 Replies Last reply
