    Backward and forward buttons on Logitech Mouse not working with Opera
    Opera for Mac
    22
    71
    92383
      A Former User @albertchong last edited by A Former User
      @albertchong try defining it for opera [upper right corner] i see you have this for all aplications, maybe this is the reason.
      i see @m4ssacre Was first with this idea πŸ˜‰
        A m4ssacre 2 Replies Last reply
        albertchong @Guest last edited by
        @dubhead I already did...see my reply to m4ssacre πŸ™‚
          Danke @m4ssacre funzt tatsΓ€chlich πŸ™‚
          Can also confirm the workaround works when config for opera is created!
            At last! Thanks for helping me to fix this very annoying issue, @dubhead, @m4ssacre, and @albertchong! For anyone just encountering this thread who doesn't speak German, here is a complete explanation of the workaround in English with screenshots.
            First, open System Preferences --> Security and Privacy, and make sure that Logitech Options is allowed to modify accessibility settings: 1 - security and privacy.png
            Second, open Logitech Options, and click on the upper right hand corner to add Opera as an application with its own special settings:
            Third, with Opera selected, click on the mouse back button to set the button up:
            Fourth, select "Keystroke Assignment" from the left-hand list, click in the right hand window to add the custom keystroke, and then press command (apple key, windows key) and the left arrow:
            Fifth, click on the mouse forward button to set the button up:
            Sixth (and finally), repeat step four for the forward button, using the command key and the right arrow:
            I have to say that having my mouse settings move up into the software layer is irritating, but F*** - software is eating the world, right?
            • m4ssacre
              m4ssacre @Guest last edited by
              @dubhead It was Teamwork at least πŸ˜‰
                Yet another person confirming this annoying bug. Mouse buttons for forward/back no longer work. Opera folks, please fix! Off to Chrome for the time being...
                  @botisdale We solved the problem,. Just read above 😏
                    @dubhead Though the forum topic refers to Logitech mice, it's not limited to just those (mine, for example, isn't Logitech) - consequently, the 'solution' doesn't apply to me. And while I appreciate the proposed solution, I'd really rather they just fix the problem. Worked fine before, no reason it shouldn't again.
                      tcar984 last edited by
                      Keystroke mapping workaround no longer works. I'm on Opera 60.0.3255.170, macOS Mojave 10.14.5 and using Logitech MX Vertical. This bug really needs to be fixed by Opera devs.
                        m4ssacre 1 Reply Last reply
                      • m4ssacre
                        m4ssacre @tcar984 last edited by m4ssacre
                        @tcar984 said in Backward and forward buttons on Logitech Mouse not working with Opera:
                        Can't confirm on MacOS High Sierra 10.13.6 - it's still working. But YouTube does something strange: At Channel landing page, Command+Left /+Right are used to switch the focus of the tabs "Overview" - "Videos" - "Playlists" etc. So if the Webpage is listening to the keystrokes, they don't work in the browser window (except you pull focus off of it).
                          I got the same problem since the first stable version of Opera 58. The three finger swipe left/right gesture on my MacBook Pro is also still not working...
                          I reported this bug months ago, got a mail that it will be fixed in a beta version, but this bug is still there.
                          If an Opera dev is reading here: Are there any news about a bug fix? Thanks in advance!!!
                            Totally Worst Support ever Opera uninstalled πŸ™‚
                              And you chose to make that as your first post, and to a year-old thread?
                              And for the record, the buttons on my Logitech trackball work perfectly in all versions of Opera without any special settings.
                                ? A P 3 Replies Last reply
                                @eprog625 Let's try to keep this positive. I agree that Opera haven't formally replied, and that is frustrating, however there is a good workaround.
                                  A Former User @sgunhouse last edited by
                                  @sgunhouse I have to disagree on that. With the Workaround of the Logitech Software setting, the backbutton on the mouse is now working, BUT the "focus bug" of the Opera Window still remains since half a year now. For example I am using the app "Magnet" to quicklyput windows on predefined corners of the screen, but with opera this only works if i have a single Opera Window opened. As soon I open a second Opera window, it doesn't work anymore and i have to close the browser. If i want to have to windows side by side I now have to use firefox on macos. The back and forward buttons and the app "Magnet" as well as other apps that help managing windows definitly worked with Opera 59 and lower (without any workarounds).
                                    albertchong @sgunhouse last edited by
                                    @sgunhouse The post is 6 months old, and whilst I agree that my logitech trackball is working fine, I paid a premium for MX Master and MX Master 2 devices and I would rather use them than my trackball.
                                      plolrt @sgunhouse last edited by
                                      @sgunhouse Sorry but this thread is less than 6 months old and the problem is not solved if you don't install Logitech software. Forward and Backwards buttons works like a charm out of the box in any other browser.
                                      In Opera buttons are working only while having the mouse on the border of the window.
                                      Reply Quote 3
                                        @sgunhouse the fact that it works for you on Logitech trackball doesn't mean it works in general. For me on macOS even with Logitech Options installed it is not working when using MX Vertical. The only workaround I found successful is to move the mouse cursor to the far edge of the screen (to get a window resize cursor) and only then backward and forward buttons are working.
                                        Judging by the comments on the thread, conclusion is that your setup is an edge case and basic functionality is broken for majority.
                                        • m4ssacre
                                          m4ssacre @Guest last edited by m4ssacre
                                          The focus thing is a bug and should be fixed. Nothing to discuss about it as long as there are no news.
                                          @Luobin I'm using SizeUp on MacOS Mojave (10.14.6) and it works fine with multiple Opera Windows (63.0.3368.107). But yes, using another application should not be the solution.
                                          By the way: The bug is still not fixed as of update 64.0.3417.47
                                            @albertchong
                                            I have been a Opera user since 2002 but never see this worst support!
                                            Bye-Be Opera Hello Safari + Chrome! πŸ™‚
