    Can;t edit/delete Speed Dials
    72
    63537
    • keitht
      keitht last edited by
      did not help gave me speed dial folder which is more junk on opera screen which I don't want and can't get rid off
        jumpingjackflash @Guest last edited by
        @vegelund Also have the same problem. Not only can i not delete individual speed dials, but it has randomly added a lot of junk speed dials to advertised sites that i do not want. Poor effort.
        • G
          garyullo @copeppe last edited by garyullo
          @copeppe Same here.
          Windows 10 Pro 22H2 (Comp. 19045.2846)
          Opera Version: 98.0.4759.15
          Three dots: useless.
          Can't edit, add or delete.
            amp40 @garyullo last edited by amp40
            @garyullo Have you tried adding context? as above
              keitht G 2 Replies Last reply
            • keitht
              keitht @amp40 last edited by
              @amp40
              dont know how last post is not very clear ?
              • keitht
                reset opera through update/recovery 3 dots worked for about 1 mon tgen back to not working disabled all extensions no difference 3 dots still not working !
                  amp40 @keitht last edited by
                  I use google translate. I don't know if the translation is ok, but a few posts above I showed what to do to make the three dots work. It helped me and a few people.
                  • G
                    garyullo @amp40 last edited by
                    @amp40 I don't know what you mean with "context".
                      leocg burnout426 2 Replies Last reply
                      leocg Moderator Volunteer @garyullo last edited by
                      @garyullo Workspaces, I guess.
                        G 1 Reply Last reply
                        burnout426 Volunteer @garyullo last edited by burnout426
                        @garyullo Click the 3 dots at the bottom of the sidebar. At the top of the sidebar settings that opens, you'll see "Workspaces". Whether "Workspaces" is enabled or not, if you only have one individual workspace enabled (just "Workspace 1" for example), clicking the 3 dots on a speed dial won't do anything.
                        To work around this (again, whether you have "Workspaces" enabled or not), you have to have more than one individual workspace enabled. So, enable "Workspace 2" for example by selecting the radio button to the right of it (that shows a white checkmark with a blue background when that workspace is enabled). In the case of "Workspaces" being disabled, you'll have to temporarily enable it to be able to enable an additional workspace. Then, you can turn "Workspaces" back off if you want.
                        This issue doesn't affect users by default because Opera has both "Workspace 1" and "Workspace 2" enabled by default. It only seems to affect users that have disabled "Workspace 2" fr example os that only 1 (the main one) is enabled.
                        Reply Quote 5
                          G P 2 Replies Last reply
                        • W
                          wildhunt @leocg last edited by
                          @leocg no its not mate, ive even thought it as a bug in the thread, its been 5 days..from 29th to 3rd SoOo far, cant delete, or discard useess apps i dont use, and that goggle search bar is eyesore anyway.. the 3 dots dont work, and the face keeps repeating...not happy
                          • keitht
                            What's Workspace google translate got anything to do with removing unwanted tiles I enabled Workspace and achieved nothing it's another useless addon that I don't want.
                              @keitht @burnout426 He described it well. I don't use Workspace and have it turned off. But that's what broke, and this solution helps (at least for some people). This works for me and I have Workspaces turned off. It doesn't matter if you reinstall opera, because then the bookmarks that are there can be edited until you sync and add your own,
                              then it stops working. This happens on stable and dev and works fine on GX. Why didn't it work for you? I don't know, either you did something wrong (though I doubt it) or it's the operating system's fault. I have win 11 and as I wrote it works. Due to the blurring of the font,
                              swipe down (through the smiley for rating) and a slight color change I switched to GX for the test, there are no such problems here
                              • keitht
                                Thx Amp40 opera GX seemed to solve the problem 👍
                                • G
                                  garyullo @burnout426 last edited by
                                  @burnout426 Thanks! It worked like a charm.
                                  • G
                                    garyullo @leocg last edited by garyullo
                                    @leocg Thanks for your tip. I had it disabled from ever so, I've forgotten it even existed. Your answer and the more detailed from @burnout426 led me to the solution.
                                    Thanks to both!
                                    • G
                                      Generosus last edited by Generosus
                                      Issue solved.
                                      We switched to Google Chrome and installed the extension "Visual Bookmarks." Result? See below. Perfect.
                                      When Opera Developers can come up with something like this, and fix its numerous bugs, we'll switch back to Opera (not Opera One).
                                      Not bashing Opera, simply trying to make a point.
                                      Salud!
                                        thatlukeguy last edited by
                                        Wielkie dzieki! This worked great. This is the solution for now until they fix the bug.
                                          klbjcb last edited by leocg
                                          This Drove Me Nuts till I read what someone said: Enable Workspaces in Settings. Then enable sidebar and you will see a Blue Square on the sidebar. Right Click on the Blue Square and Tap on manage workspaces. Enable workspace 2 by tapping on the circle and it will show a blue dot. That is it - Now Everything Works - Why Would Someone Make This Change And Not Tell Anyone How To Fix Things Back To Normal?!?
                                            A Former User @amp40 last edited by
                                            @amp40 This actually works, thanks !
                                              S 1 Reply Last reply
