    Can;t edit/delete Speed Dials
    72
    63835
      @boultan Strangely, it keeps working even if you disable workspaces - as long as there were still 2 when you disabled it. As soon as you remove the second workspace, the context menus are gone again. Weird.
        I pointed out to the developers the link to workspaces and they say they should have a fix soon.
        • Referenced by  burnout426 burnout426
          pjsmith @burnout426 last edited by
          @burnout426 Thank you. I was scratching the head on this one 🙂
          • graywoulf
            graywoulf last edited by
            Not only can I not edit my speed dials but I can't use the Google search bar at the top of the page. This needs to be fixed... fast!
            graywoulf
              leocg Moderator Volunteer @graywoulf last edited by
              @graywoulf Why you can't use the search field?
                graywoulf 2 Replies Last reply
              • graywoulf
                graywoulf @leocg last edited by
                @leocg, Well earlier, I was not able to type anything on the search line at all. I had to go directly to Google to do a search but I just tried it and it is working now. Strange. I sure hope that the speed dial issue is fixed soon though. Thanks for your reply
                graywoulf
                • graywoulf
                  @leocg Hi again. About the Google search bar, I was wrong in that I could not use it to do a search. What I cannot do is copy something and paste it to the search bar. I am glad that I had the Google search page as a speed dial as I can paste text there. Any ideas on that issue?
                  graywoulf
                    @graywoulf There are some topics/posts about it. You can use the keyboard for now.
                      graywoulf 1 Reply Last reply
                    • graywoulf
                      @leocg Thanks for your reply and suggestion. Ctrl-V does work quite well.
                      graywoulf
                      • O
                        OwnYourStep last edited by
                        I used to be able to, but when I tried to edit/remove a shortcut from my speed dial yesterday I found I was unable to. Neither clicking the 3 dots in the thumbnail nor right clicking on the shortcut thumbnail opened the menu to edit/remove. Anyone else having this problem? And more importantly ... how do I fix it?
                          leocg Moderator Volunteer @OwnYourStep last edited by
                          @ownyourstep Check above
                          • graywoulf
                            My sincere gratitude to the tech(s) that fixed these issues. 👍 👍
                            graywoulf
