    Addons "Cashback Web Monitor"
    Opera for computers
    38
    100
    92250
      %50 CPU usage, when I browse binance and its keep increasing.. I dont want any nonsense like this..
        sergas last edited by
        I confirm. When using Binance web site a huge memory leak and processor utilisation problems with this extension.
          Same problem, please fix it 😞
          Reply Quote 3
            adamwwa last edited by
            I have same problem. It is almost impossible to use Opera with opened Binance.
              Omg, with that bug i cant work with tradingview and my broker site. Good bye Opera? 😠
              What wrong with last update?
              Reply Quote 3
                morisveca last edited by
                Same with 75.0.3969.35.
                  Same here, I'm also using Binance and TradingView and Opera just freezes. I'm also on W10 latest build. Will this be fixed? There's already a lot of complaints about this. I've already switched to Chrome until a new opera update is released.
                    Have been running Opera Developer 76 for a while with https://br.tradingview.com/chart/?symbol=BMFBOVESPA:IBOV&source=unauth_header&feature=launch_chart and https://www.binance.com/pt-BR/trade/ETH_BUSD pages opened and, so far, I couldn't reproduce the problem.
                      adamwwa @leocg last edited by adamwwa
                      @leocg Maybe you should try to use stable version like most of user. On 74.0.3911.203 problem exist. This is state after 2 minute. After 60-80 minute I had 4-5GB.
                        leocg Moderator Volunteer @adamwwa last edited by
                        @adamwwa I already had checked with Opera Stable but I will do it again.
                          A leocg 2 Replies Last reply
                          andrew84 @leocg last edited by andrew84
                          @leocg On you 'binance' link I have different results than previously. More than 200MB already and it continues increasing slowly. So
                          I think I can confirm the bug also
                          Edit: more than 300 already
                          Edit 2:
                          almost 500 already
                          • G
                            gmp last edited by
                            A similar problem. The "Cashback Web Monitor" extension consumes 2GB of RAM.
                            Opera 74.0.3911.203 / Win 10 v1909 x64 / Opened 210 tabs / Uptime 7-8 days.
                              What is this? How can I disable it? Has a high CPU and memory load.
                              Version:74.0.3911.203
                              Update stream:Stable
                              System:macOS Version 11.2.2 (Build 20D80) 11.2.2 64-bit
                              UPD: It looks like this is a global problem. https://forums.opera.com/topic/47377/addons-cashback-web-monitor
                                andrew84 @andrew84 last edited by
                                @andrew84 close to 1GB now and I'm finishing the experiment.
                                  leocg Moderator Volunteer @leocg last edited by
                                  OK, I checked again with Opera Stable and could see the memory usage for the addon increasing.
                                    jackseg last edited by
                                    Same problem here since last update 😞
                                      lexabesed last edited by
                                      The same problem, after updating to version 74.0.3911.203, the opera constantly loads the processor by 30% also, even after closing the browser, this process remains and still loads the processor, only the end task through the task manager helps
                                        I have been testing 76.0.3989.0 for 12 hours and there is no problem with cash back plugin. 😃
                                        Maybe it is a solution until they fix it.
                                          serge0333 last edited by
                                            flmatei last edited by
                                            same problem here
