    Addons "Cashback Web Monitor"
    Opera for computers
    38
    100
    92203
    • I
      ilyahawkin last edited by
      Cashback Web Monitor Eats up half of the processor
      • I
        Fix
        opera:flags
        disable Cashback
        alt text
          ? ? 2 Replies Last reply
          A Former User @ilyahawkin last edited by
          @ilyahawkin disabled, but does not help
          still eats lot of cpu
            @ilyahawkin i tried that, but no help. it just keeps running no matter what. like a persistent malware
              I 1 Reply Last reply
            • I
              ilyahawkin @Guest last edited by
              @emanuel1788 as a temporary fix, revert to the old version by renaming the exe file names
              alt text
                ? leocg 2 Replies Last reply
                @ilyahawkin well i have a lot of versions.. i don't know exactly which one to go back...alt text
                  leocg Moderator Volunteer @ilyahawkin last edited by
                  @ilyahawkin It needs more to revert to an old build.
                    @leocg any tutorial for that please?
                      This thing keeps eating memory and cpu making the browser sluggish and unresponsive. please let us disable this crap
                      alt text
                      Reply Quote 3
                        @emanuel1788 The easiest way would be to download and install an older build and block autoupdate, but you can also edit installation_status.json so that it point to the older version folder.
                          @leocg thank you ill try
                            Hello,
                            I love Opera since the introduction of Workspaces and since there is no other browser that does this (not to my knowledge anyhow) I tried to end process of the Cash Back Web Monitor several times and it seems that after 3 times it doesn't start anymore (until the next opera open action 😛 )
                            So I did like this:
                            1. Open Opera
                            2. Press Shift +ESC (this will open Opera's Task Manager)
                            3. Sort Task by name (to find Cash Back Web Monitor )
                            4. Click Cash Back Web Monitor
                            5. Click End Process (which is found on the right bottom corner)
                            6. Let it restart again
                            7. Click Cash Back Web Monitor
                            8. Click End Process (which is found on the right bottom corner)
                            9. Let it restart again
                            10. Click Cash Back Web Monitor
                            11. Click End Process (which is found on the right bottom corner)
                            I hope this will work until the new version will fix it. I have the OPERA opened for 10 minutes now and it didn't start again.
                            Cheers
                            • W
                              winblood last edited by
                              To Opera we're only shoppers now. This is what it is, when it's free you are the product. Thanks for all those years, but this is the last straw. Going to Firefox.
                                I'm having the same problem as well. Opera's CPU usage climbs slowly and steadily over time until it starts lagging my entire computer, at which point I have to restart it. I'm on Opera v74.0.3911.203, running an intel i5 9800F on 64-bit windows 10.
                                  @eddieu
                                  @eddieu said in Addons "Cashback Web Monitor":
                                  Hello,
                                  So I did like this:
                                  1. Open Opera
                                  Cheers
                                  this actually works. thanks
                                    Ok, first I really want to Thank the original poster and other members of this thread who just saved me from insanity. An UI I'm developing makes heavy use of both the Tradingview chart embedded module and the websockets, which were mentioned above as the "cashback monitor" triggers. I noticed that the UI started to freeze often lately and spent a couple of days profiling memory usage left and right until I spotted that satanic beast in the Task Manager (apparently, the only place in the browser where technically inclined users may accidentally notice it). Now, my UI consumes quite a bit of resources because of some heavy calculations, but this thingy beats it in just few minutes:
                                    alt text
                                    And yeah, even after you kill it, it keeps rising from the hell as a pesting zombie. What a marvellous decision to improve your users experience, Opera!
                                      W I 2 Replies Last reply
                                    • W
                                      winblood @Guest last edited by
                                      @curiouscroc Found a solution, installed the Vivaldi browser, how ironic! 🤣
                                        ashmchapman last edited by
                                        Same issue, seems to be related to using trading platforms like "binance" that use "tradingView" live graphs.
                                        Had no issue with this a week ago.
                                        I'll be switching to another browser in the mean time.
                                        Hopefully Opera can fix this quick enough before I settle into a new browser.
                                        • I
                                          ilyahawkin @Guest last edited by This post is deleted!
                                            elcool last edited by
                                            74.0.3911.218 has solved the issue. Cashback Web Monitor extension is not even running anymore.
                                            Vivaldi is good browser but UI lags so much compared to Opera to the point I can't stand it 🙂
