    [Solved] Speed Dial Background
    3012
      browzer1 last edited by
      Is it possible to set the Speed Dial background (wallpaper) to a solid color? In my case, light blue.
      I know it was possible some versions ago but that capability seems to have disappeared. I wish someone would develop wallpapers with just solid colors.
      If it is possible, could someone point me to the necessary instructions please.
      • O
        operafanuk last edited by admin
        Try checking wallpapers in Opera Add-ons, find one then add it to Opera. Then go to settings and choose desired wallpaper.
        Or find the wallpaper you're after, and copy it into "themes_backup"
        Check this link to my closed thread which addresses this, and which worked for me.
          You should be able to set any image as theme, so just find one that fits your needs and use it.
            leo ... how?
              Right-click on image > Use image as wallpaper
                Or right click on Start Page /Speed Dial > change wallpaper > click on the plus button.
                  Thanks to all that replied. I found a color (image) and dragged and dropped it. Works perfectly.
