    Problem logging using Opera browser
    Opera Mini
    9
    10
    3987
      abhirup777 last edited by
      I can't login into my any account in Yahoo or rediffmail or anywhere using Opera mini but I can do it using other browsers. Do I need to change any settings?
        emoller last edited by
        Hi, if you have a mini issue you should post it in the Mini thread to make sure you get a good reply. Opera for Android is the full browser on Android and is not the same product.
          Topic moved…
            mbaluta last edited by
            @abhirup777, what problem do you exactly have? Which URL do you use to login and what version of Opera Mini do you use? What platform - Android, iOS, J2ME?
              twozero3 last edited by
              I also have problems logging into Yahoo services via Opera Mini for Android (v8 beta4) running on BB10.
              The fact I have to run Mini through BB10's Android runtime may in itself may be the reason for the partly disfunctional performance of Opera Mini. Hey Opera how about a dedicated BB10 version of Mini and Mobile 🙂
              Just yesterday I tried to log into Flickr through Mini. Yahoo rejected the log in attempt due to the unknown log in location... according to yahoo that was Iceland. I'm guessing Opera have some proxy servers there. Yahoo directed me to answer my security question but having typed it in Mini did not highlight the continue button and I just kept going around in circles being thrown back to the same security question.
                @twozero3 On https://login.yahoo.com/m you shouldn't have this problem.
                  Thank you. That has worked.
                  How strange that attempting to login via the standard Yahoo home page (in my case www.yahoo.co.uk) does not work properly.
                    mulekoh last edited by
                    I have downloaded opera 38 and I am having issues logging into my accounts. Is there a setting I missed?
                      There is no Opera Mini 38.
                        smyru last edited by
                        @mulekoh, what are your symptoms?
