    Add to Speed Dial not working
    Opera for Android
      forestlover last edited by
      Why can't I add a website to the Speed Dial?
        leocg Moderator Volunteer @forestlover last edited by
        @forestlover If you don't provide any information, no one will be able to try to find out.
        What happens when you try to do that?
          forestlover last edited by leocg
          I cant's simple. I click on + to add a new URL shortcut. Add Speed dial appears. I paste in the URL and press return. Nothing happens.
            A leocg 2 Replies Last reply
            andrew84 @forestlover last edited by
            @forestlover It happens after updating to 81 version?
            There should be some 'improvements' related to the speed dial creation according to the changelog.
            https://forums.opera.com/post/345312
            But here I see only 'Add site' button on top of the opened blank page, no confirmation buttons or similar. I don't understand what improvements were made. Fortunately, I usually use the 3 dots menu when web site is opened to add the site to speed dial.
              @forestlover Just checked and it seems that I could confirm the problem.
              If you type the address and press return (here it's a search button) the address is add, but if you paste the address, nothing happens.
              To add an address by pasting it you need to click on the + next to it
                Thanks everyone. The "+" may not work but the three dots on the webpage does, so I will use that method from now on.
