    My Flow: Can't connect desktop and phone topic
    Opera for computers
    flow my flow
    61
    71
    93904
    • W
      wileee last edited by
      Using latest MacOS Opera One(version: 106.0.4998.52) (x86_64) and latest iOS version - flow's not connecting by any method (but most here is about Android as I can see)
      If you have any fresh updates for iOS, please let me know
      Thank you
        NiaDoodle @Guest last edited by
        @kanczo the fact that it's currently February of 2024 and this problem still exists is wild to me, being that this thread was started in 2022 .-.
        I'm so glad that that solution worked for me, cause I tried so many different things to try and get it to connect before stumbling across this topic.
          rahimgg @Guest last edited by
          @kanczo Thank you, it worked for me. trying to find a solution and this just work.
          • Referenced by  M mstfcbngl
            @kanczo Same issue in 2024 and this still works 🔥
              Derpybat last edited by
              I was having the same issues. SO instead of using the Code reader in flow, i used the other one in the search browser. and that worked for whatever painful reason. HOpe this helps someone
                Danny2opa @Guest last edited by
                @kanczo Thanks a lot, it worked, this problem was driving me crazy!
                  ltBanshiro @Guest last edited by
                  @kanczo Worked for me, thxxx
                  • Referenced by  A achhid
                  • H
                    hossdelgado last edited by
                    I know this post is old but I was having the same problem. I was not able to connect android opera to my PC running opera GX. I WAS however able to get it to work when both devices were running GX. Super annoying because GX for android wont let you sign in but I digress as this is a solution and allows me to have flow on both devices. Hope this helps...
                    • O
                      offonja @Guest last edited by
                      @kanczo thanx! it finally worked for me.
                      but Opera team should solve the issue
                      • W
                        still.. nothing works for iOS 😕
                        • Referenced by  C Chri-73
                        • Nickname164
                          Nickname164 last edited by
                          My opera on my computer just skips the part that says do the codes match leaving my phone doing nothing.
                            falone @Guest last edited by
                            @kanczo said in My Flow: Can't connect desktop and phone topic:
                            I found a solution th the problem described by OP.
                            When your phone is on the "Follow thee instructions on other device" screen, just press the "Overview"(switching apps) button and force-close Opera. When you relaunch opera on your phone, flow should be already connected.
                            It worked for me, it may not work for you, but i'm trying to help as much as i can.
                            Can't do this with more then 1 PC. On 1 PC it worked great, but on second - just log-out right after scanning the code.
                              NonReal025 @Guest last edited by
                              @kanczo Thanks so much. It worked.
                              • Y
                                Yondamine @Guest last edited by
                                @kanczo that's so stupid to do that, thank you a lot, I was going to go back to chrome only for this issue, I was so disappointed,
                                  buzdard @Guest last edited by
                                  @kanczo workx also in 2024, pls anybody pin this
                                  • jediknight36
                                    jediknight36 last edited by
                                    Im having a similar issue. It doesnt often go to the "you're connected" screen. Instead, I get this one after I scan a QR code from any place in Opera. This one was taken from opera.com.connect , I get a failure on the phone eventually. Anyone have any idea?
                                    • jediknight36
                                      jediknight36 @Guest last edited by
                                      @kanczo This worked for me!
                                      Thank you!
                                        Art-Shpiller @jacksth22 last edited by
                                        @jacksth22 This worked. Thank you!
                                          morgen401 @jacksth22 last edited by
                                          @jacksth22 Thanks . It works now.
                                            LongJonStudd @DCscotland last edited by
                                            This is the solution from @dcscotland:
                                            I had this problem after having to do a factory reset on my mobile due to an unrelated issue. I reinstalled Opera for Android, but Flow on the app would no longer connect with Flow on Opera 89 of my Windows desktop.
                                            I rolled back to Opera 85. Flow then connected between both devices as normal. A few hours later I was alerted to the Opera 89 update. I installed it and the Flow connection remained in place. No further problems since.
                                            So I went to https://blogs.opera.com/desktop/2022/04/opera-85-0-4341-60-stable-update/ and clicked the Download Now button with the little Windows logo (I'm running Win 10).
                                            I promise you, it won't even take hours. Once you install this update, you will instantly get the confirmation instructions for the two numbers, and your My Flow will be off and running!
                                            Shut down all running Opera windows first, naturally.
