    My Flow: Can't connect desktop and phone topic
    Opera for computers
    flow my flow
    61
    71
    93906
      tigermanoiu last edited by
      So I use a mac book Air M3 and an iPhone 13, which both have Opera, and when I try to connect to Flow there, the QR code scans on my phone, but it just loads and loads and loads until it says error could not connect
        K 1 Reply Last reply
        fdlulix @Guest last edited by
        @kanczo Bloody saviour. It worked for me as well.
          tomak147 @Guest last edited by
          @kanczo THX a lot
            RJF-Campbell last edited by
            In the end I had to delete on my phone (Samsung android), reinstall, then set up sync and flow. Connected and worked perfectly after that.
              AutisticMumTo3 @Guest last edited by
              I'm having the same problem
                Play4UK @Guest last edited by leocg
                @kanczo said in My Flow: Can't connect desktop and phone topic:
                I found a solution th the problem described by OP.
                When your phone is on the "Follow thee instructions on other device" screen, just press the "Overview"(switching apps) button and force-close Opera. When you relaunch opera on your phone, flow should be already connected.
                It worked for me, it may not work for you, but i'm trying to help as much as i can.
                So this didn't help at all cuz when I scan PC QR code with my phone, and force close it does nothing.
                But I found another solution. that may help
                The problem was a DNS server, I'm using NextDNS website to create a private DNS for me to block ads, trakcers etc, and I'm using it on my tablet and 1 phone and on my 2 phone I'm not using it. So in my case all I had to do is go to phone settings > DNS > Change from Private DNS (maybe even with Automatic DNS there is a problem) Change from Private DNS to Off > Restart your phone or just wait a bit and Done, now Flow will connect with no issues at all! After you connected your flows, you can switch back to Private DNS or Automatic whatever you used before.
                • rukyesneda
                  rukyesneda last edited by
                  After a year trying to connect my flow between my computer and my phone, I finally succeeded. I did several things at once. I log out from my opera account in my laptop, then in my phone I closed all the tabs, then went to settings - apps - opera - storage - clear cache and the other storage, then uninstalled the app and installed again. Once installed, when I opened it I said yes to everything, I let it be the default browser in my phone, and gave it permission to take my info (those are the two messages that pop up when opening the app). I opened flow, in the computer with the qr code and in the phone, too. First flow connected in the pc, but gave me an error in the phone, I did the same thing again and it jumped to opera connect, appeared the code, the computer synced up, then again the same, the phone synced up, and finally after four qr codes scanned, my flow connected. I don'
                    Karma-3 @tigermanoiu last edited by
                    @tigermanoiu The same thing is happening to me, my phone (samsung A13) just keeps loading, doesn't show any code, and my computer (microsoft windows 11) doesn't move on from the qr code. I used to have flow but one day it just disconnected (probably due to an automatic update) and now it doesn't want to connect again.
                    Nothing shared here is working, this issue has to be fixed, it's ridiculous that this still happens after years.
                      marhoni last edited by
                      apparently there's some bugs, or just human error,or i called it lazy to read idk. But when i try logging out my opera account on both pc and android, and try linked the flow with qr code its working, like its that simple, then why we need to sign up for opera's account then?
                      • Mlipka
                        Mlipka last edited by
                        Guys, if you have any issues with My Flow, please create official ticket.
                        This way engineers can actually see the scale, investigate. Keeping it, in this old thread doesn't help anybody.
                          deepanKishotre @Guest last edited by
                          @kanczo
                          Thanks. This works. apparently, there is a bug in flow sync and this method overides it. Hopefully someone notices this issue.
