    Speed Dial Wallpaper changed unexpectedly
    windows 10 speed dial wallpaper
      FerdinandA last edited by
      Hello everyone,
      This weekend, while using opera, my Speed Dial's wallpaper swapped to a photo of someone I don't even recognise.
      I checked my downloads afterwards and found it there, so it was both downloaded and set as a wallpaper without my input whatsoever.
      I've never even changed my wallpaper from the default, and I've made no changes to my browser - nothing but generally browsing and setting bookmarks - in about a month or so.
      Honestly, I have no idea what could have led to this on my end.
      (not sure if relevant, but I'm using Opera 85.0.4341.75 on Windows 10 64-bit)
      Does anyone know what might have caused it? Please let me know, and thank you.
        S 1 Reply Last reply
        sgunhouse Moderator Volunteer @FerdinandA last edited by sgunhouse
        @ferdinanda You right-clicked on the image for some reason then accidentally hit Set as wallpaper instead of whatever you meant to hit?
          F 1 Reply Last reply
          FerdinandA @sgunhouse last edited by
          @sgunhouse Thanks for the reply, that's definetly possible, but I think it's unlikely as I'm absolutely possitive I've never seen the photo. Actually, I've never seen whoever is in the photo either.
          I've also tried reverse-searching trough Google images, and didn't find a single match for it. So, I don't think that's likely to have happened.
