    [Solved]speed dial in Opera android
    Opera for Android
    solved
      miker84 last edited by leocg
      I love opera but hate their choice of connections in speed dial on my phone, does anyone know of a way to edit them?
        S 1 Reply Last reply
        sgunhouse Moderator Volunteer @miker84 last edited by
        @miker84 Add ones you want, remove ones you don't. Long-press a tile to see options. How else would Android work?
          M 1 Reply Last reply
          miker84 @sgunhouse last edited by
          @sgunhouse Thank you, I just wasn't holding the tile down long enough or perhaps hard enough. Anyway all is now ok.
