    Flow doesn't work with walmart.com
    Opera for Android
    • rif
      rif last edited by
      Android version 61.2.3076.56749
      Desktop version 73.0.3856.284
      Steps to reproduce....
      Go to walmart.com
      bring up any item
      send to flow
      try to open on desktop and you end up with a url like this....
      https://web.flow.opera.com/ip/Hamilton-Beach-3-Cup-FreshChop-Mini-Food-Chopper-72603/454902455
      Tried switching to desktop version but that doesn't help
      I use flow a lot and have never run across this before.
        sgunhouse Moderator Volunteer last edited by sgunhouse
        What is the original URL for the same item? Wondering if there's some character in there the server can't handle.
          rif 1 Reply Last reply
          I've tried with https://www.walmart.com/ip/Somerset-Home-Series-Microfiber-Sheet-Set-Blue-Twin/27534432 and got the same problem.
          • rif
            rif @sgunhouse last edited by rif
            When you go to a particular item on walmart.com either on android or desktop it gets displayed with the same url.
            I tried sending that url to android via flow and it displays fine on android,
            When you try and send it back to desktop it gets changed to:
            https://web.flow.opera.com/ip/Somerset-Home-Series-Microfiber-Sheet-Set-Blue-Twin/27534432
            I filed a bug report
              Sounds like the site code probably uses relative links and they aren't converted somehow ....
