    Why does Opera keep signing me out of everything?
    38
    51920
      Has been happening to me recently, a few weeks ago. I have several emails I need to be logged in for various things. Was super annoying having to login every time I turn my laptop on every morning. Currently using another browser till this is resolved.
      • alobpreis
        alobpreis last edited by
        That's weird. I suggest you try Opera portable to check if it's something specific to your installation or profile.
          There's a Windows 10 bug that causes this issue in Chromium-based browsers. See more about it at https://bugs.chromium.org/p/chromium/issues/detail?id=1069383.
          Make sure you're using Windows 10 20H2 and that you install KB4598291 from windows update.
          If you can't install the newest version of Windows 10 and can't install that update, see this page for a workaround that involves finding one more more scheduled tasks that trigger the bug so that you can disable them.
            V 1 Reply Last reply
            VascoF @burnout426 last edited by
            @burnout426 After I did what you referred the issue was solved. I was with this issue for months and I was getting really bored of it.
            Thanks a lot for your help.
            Regards
              There is a setting in Google Chrome which allows you to clear your history every time that you close the browser. I assume that this is the same for Opera since it is based on the Chromium engine.
              You may want to consider signing into your Opera browser using an Opera account. It's quick, easy and free. You can go to your browser's settings and create one.
              If this doesn't work, you might want to try and extension. You could use the Opera Extension Store, or the Chrome Web Store. I am sure that there are plenty out there.
              Hope this helps!
                T 1 Reply Last reply
                So my laptop recently updated, ever since, the signing out issue doesn't happen. I never had this issue before so I was confused, no solutions seem to be working. I hope it doesn't happen again.
                  tanja012 @Guest last edited by
                  @oliverdavis2006 Thank you!! I tried everything with no luck... but your post made me look for a setting in opera like that in chrome.. I found it! it was apparently turned on as a default when I installed the browser.
                  for anybody with the same problem:
                  safety & privacy -> cookies and other webdata -> clean cookies and webdata when closing opera. --turn this off.
                  • H
                    HaiChivas last edited by
                    okay i found the solution, you go to the setting, in the "Private and security" section, you go to the "Cookies and other site data" you can find a line which is "Clear cookies and site data when you quit opera". Switch that off and you can now save your login.
                      A Former User @HaiChivas last edited by
                      @haichivas Or reintalling the browser.
                        @waynemccrimmoniiyt unless you don't want to loose a lot of open tabs... Also.. It might not solve it as mine had the wrong setting when it was installed.. But it is so easy to go to settings like I wrote earlier.. No need to uninstall😊
                          A Former User @tanja012 last edited by
                          @tanja012 ok
                            i also have this problem but it is every time i shutoff my laptop
                              S 1 Reply Last reply
                              @isd Some software that is run at startup is deleting your cookies. One program I know that can do this is Ccleaner, if you have that you'll need to change its settings to get it to stop deleting cookies all the time. If you don't use Ccleaner, then check your other "Internet security" or "privacy" software to see if it has a similar option enabled.
                                Bravemarcus last edited by
                                Why does my opera log me out of websites then i try to log in again but then says that my password is wrong like discord
                                  alobpreis 1 Reply Last reply
                                • alobpreis
                                  alobpreis @Bravemarcus last edited by
                                  @bravemarcus If you get a wrong password message, then the password has to be wrong. Maybe Opera has an old password stored? Try an Incognito window and manually type the password to be sure.
                                    I 1 Reply Last reply
                                  • I
                                    InfinityApps last edited by leocg
                                    this is so frustrating !!!!
                                    It just logged out in front of my eyes
                                    how to fix this ?
                                    Reply Quote -1
                                      P 1 Reply Last reply
                                    • I
                                      InfinityApps @alobpreis last edited by
                                      @alobpreis what a irrelevant response
                                      Reply Quote -1
                                        PonchyNews @InfinityApps last edited by
                                        @infinityapps I have this same aggravating as hell probelm!!!1
