    [Solved]Speed dial became smaller
      Nico-0 last edited by leocg
      Before the Opera 62 update, the speed dial occupied the whole page.
      Now there's only 6 elements per line, and its a real problem since now I have to scroll like a full page, when before I could see everything at once.
      Is it a setting or something?
        leocg Moderator Volunteer @Nico-0 last edited by
        @Nico-0 Maybe, check Easy Setup and the settings page.
          They added a setting to "Automatically adjust the maximum number of columns" which - if enabled - seems to limit you to 6. Disable it and your previous default should return.
            N 1 Reply Last reply
            Nico-0 @sgunhouse last edited by
            @sgunhouse Awesome, that did it, thanks!
