• 登录
    • 搜索
    • 版块
    • 最新
    • 话题
    • 用户
    • 群组
    My flow "failed to connect"
    Opera Touch
    my flow connection
    107
    169
    198170
    正在加载更多帖子
    • 从旧到新
    • 从新到旧
    • 最多赞同
    回复
    • 在新帖中回复
    登录后回复
    此主题已被删除。只有拥有主题管理权限的用户可以查看。
    • Phoenixoboros
      Phoenixoboros @RealestNooby 最后由 编辑
      @realestnooby this would be my third device.
      回复 引用 0
        RealestNooby 1 条回复 最后回复
      • RealestNooby
        RealestNooby @Phoenixoboros 最后由 编辑
        @phoenixoboros it should work, otherwise it would just say replace
        回复 引用 0
          1 条回复 最后回复
        • bhanukode
          bhanukode @游客 最后由 编辑
          @mwfontes I did this right now and its not working.. I disconnected opera touch in my mobile and tried to connect the opera GX android (released recently) to the opera GX pc.
          Normally I guess it would've worked.
          回复 引用 1
            1 条回复 最后回复
          • YeaImAlexO
            YeaImAlexO 最后由 编辑
            Still nothing working, not working with any of the android opera versions, everything from touch to GX nothing is connecting, not trough QR and the same using the manual code, nothing.
            回复 引用 1
              1 条回复 最后回复
            • Phoenixoboros
              I had to do an "emergency/complete" reset of MyFlow to have it working again, you guys should try this as a last recourse.
              回复 引用 1
                Chestershire 1 条回复 最后回复
              • moppera
                moppera @spencerross 最后由 编辑
                @spencerross Nice to know I am the only one. Connecting Opera fails. Scan does not work neither typing in the code. Used to use flow, sad to see it's gone. Or has anybody a solution for this?
                回复 引用 0
                  1 条回复 最后回复
                • avtugrul
                  avtugrul @MateusRosolem 最后由 编辑
                  @mateusrosolem i did your solution and it worked.
                  回复 引用 0
                    1 条回复 最后回复
                  • theweird1
                    theweird1 最后由 编辑
                    OK I give up off to firefox
                    回复 引用 1
                      1 条回复 最后回复
                    • mayif1
                      mayif1 已封禁 最后由 编辑
                      I am facing this issue on opera touch. The opera mini is working pretty nicely.
                      回复 引用 0
                        1 条回复 最后回复
                      • GilbertVS
                        GilbertVS 最后由 编辑
                        Is this really true? Just having switched to Opera I am appalled to see, that this trouble has been going on for ages! Is nobody of the creators of Opera following this blog? How can such an important problem not be solve asap? In Chrome one can use the google account to sync the devices. Why not here? This is not something out of this world and should be solved asap. I do not have the nerve to test all the above. Like Chrome and FF this just has to work, right? Where are the creators/designer to fix this? Very disappointing...
                        回复 引用 0
                          1 条回复 最后回复
                        • MrBartosh
                          MrBartosh @Kexx 最后由 编辑
                          @kexx It finally worked! Thank you for sharing that solution 🙂
                          回复 引用 0
                            1 条回复 最后回复
                          • Chestershire
                            Chestershire @Phoenixoboros 最后由 编辑
                            @phoenixoboros thank you, it worked!
                            回复 引用 0
                              1 条回复 最后回复
                            • Murdock-GX
                              Murdock-GX 最后由 编辑
                              I took a screenshot of just the qr code and opened it on paint with a white background and it worked, tried so many things to get it to work and i can't believe this was it.
                              回复 引用 0
                                1 条回复 最后回复
                              • RealestNooby
                                RealestNooby 最后由 编辑
                                the fix to this is to just open it on a dark background, or turn on light mode, the reason it doesn't work is because it thinks the dark background is apart of the code
                                回复 引用 0
                                  1 条回复 最后回复
                                • luksabarovic
                                  luksabarovic 最后由 编辑
                                  Same here, Opera Flow is not working. (Showing failed to connect on mobile)
                                  Version:89.0.4447.71
                                  System:Windows 10 64-bit
                                  Stopped working after Opera for PC uptate, the other day.
                                  回复 引用 1
                                    1 条回复 最后回复
                                  • Skorgarmaor
                                    Skorgarmaor @baligo 最后由 编辑
                                    @baligo This worked!
                                    I have connected my Android phone (GX) + Windows PC (GX) + Linux Mint (regular Opera)!
                                    回复 引用 3
                                      1 条回复 最后回复
                                    • MarshallVisions
                                      MarshallVisions @游客 最后由 编辑
                                      @rassnul This saved me in 2023!
                                      回复 引用 1
                                        iloris 1 条回复 最后回复
                                      • iloris
                                        iloris @MarshallVisions 最后由 编辑
                                        @marshallvisions Same here. Sadly, this solution, the only one that works, costs the entire flow history, a several years' worth of it. It got me really mad 😕 I see a similar functionality appearing in other apps, so I guess I'll be using Opera for now, but only until I find another option that works for me.
                                        回复 引用 0
                                          1 条回复 最后回复
                                        • crind
                                          crind @游客 最后由 编辑
                                          @mwfontes it still works lmao, thanks.
                                          回复 引用 0
                                            1 条回复 最后回复
                                          • bothpills
                                            bothpills 最后由 编辑
                                            The user @kanczo suggested something in another related topic that worked for him and is now working for me as well. The 'fix' is outlined below:
                                            "When your phone is on the 'Follow the instructions on the other device' screen, simply press the 'Overview' (app-switching) button and force-close Opera. When you relaunch Opera on your phone, the flow should already be connected."
                                            I hope this works for all of you while Opera doesn't directly address this issue.
                                            Thanks, @kanczo, for coming back and sharing your solution with us!
                                            回复 引用 2
                                              luksabarovic 1 条回复 最后回复
