My flow "failed to connect"
baligo 最后由 编辑
OK people, after trying every single solution suggested in this thread (including emergency resetting My Flow) without any success, let me share how I solved the problem:
- Backing up My Flow:
- Open My Flow.
- Click somewhere on a text.
- Press Ctrl+A on the keyboard, this will select everything so you can export your precious stuff.
- Open Notepad, Word or any text editor, paste the contents of My Flow and save it.
Now that your content is backed up, proceed with the connecting steps:
- Resetting every device:
And I'm not even sure if this is needed at all (cause I already had emergency reset and didn't have the opportunity to try without this step) so at first you could try to connect without resetting and losing your data:
- Open My Flow.
- Click the three dots and then Emergency reset.
- Reset the other devices too.
Again - I'm not sure this is required.
- Connecting devices:
- Open opera.com/connect
- Click Page information icon in the Address bar.
- Click Site settings.
- Opera Settings page opens and I changed every Block to Allow.
- Now connect your devices. Reload page if needed.
- Revert back to default settings on Opera Settings page by clicking the Reset permissions button.
- Post back the contents of the old My Flow. Time consuming! I have 38 pages of clear format text without space before, after and between lines in Word to put back. Post by post.
I so hope this process works for you too and even without the resetting part.
老用户 最后由 编辑
i found the solution here https://forums.opera.com/topic/32339/opera-touch-flow-failed-to-connect-pairing-devices-not-allowed-here
I removed all my older pairings and then I was able to connect
baligo 最后由 编辑
@liewcheonfong I'm glad it worked. It took me couple days trying this and that to figure it out. Did you try without the resetting part?
老用户 最后由 编辑
Hey there, @ITAKAAAAA!
What a slippery question!
So slippery, that I fell flat on my face!
What an error!
You are experiancing an error in Opera, please contact Opera so they can fix this unexpected error...
Sorry! -
hewesscliff 最后由 leocg 编辑
Click on "my flow" where it appears to scan with the QR code, on the top corner left you will have three dots, click on them and go to "Emergency reset", I think that solves your problem.
egoistbiri 最后由 编辑
@MrGoldstick said in My flow "failed to connect":
lol I just had to uninstall opera touch app and reinstall it again. just.. wow.
I agree it is possible solution. When I uninstalled opera touch then restarted system and reconnect finally succeed. Actually I was using opera because of its flow feature. Now I do not need to use it anymore.
老用户 最后由 编辑
I had the same problem when trying to connect my new phone. Disconnecting my computer to My Flow as described above fixed it. I had my old phone and and a tablet still connected so I just reconnected the computer to the My Flow on the tablet (I suppose I could have reconnected to my old phone too) so I didn't lose all my flow history. I then connected my new phone to my flow on the computer. All good thanks.
RealestNooby 最后由 编辑
Ok here is how to fix it, open the qr code on a white surface, fixed or just open it in paint 3d
v-m-smith 最后由 编辑
@baligo said in My flow "failed to connect":
Man, you just gave me a good idea to Backup! Anyway Flow is now a good tool to search info. So I tired to do as you said - Ctrr-A to copy all selected content of My Flow - and paste it into MS OneNote - it got it like a charm! With all that pictures and links. Now I have much more usability to search for my Flow records!
BUT! But you must manually move and move slider upto to most top in My Flow until you got needed deep of timestamps of posts. Because by default My Flow shows posts preloaded for not more than couple of last months ! -
老用户 最后由 编辑
can't connect to iPhone ... I have to check the connection but I'm connected normally ...
paulorubimf 最后由 编辑
Have you tried to connect the laptop with the cell phone instead of the cell phone with the laptop? Generate the QRCODE on the cell phone, capture the screen and read the QRCODE on the laptop using any website that does this. I had the same problem, I did it that way and it worked!
