    IS VPN with problem now?
    Opera for computers
    68
    219
    326542
      A Former User @A Former User last edited by A Former User
      @acidinmyfridge said in IS VPN with problem now?:
      @flyboy interesting.
      for me, there is no change. still stays yellow and can't choose virtual connection (it's blank and grayed out when clicking the drop down).
      Ahh, you are correct. This morning I'm only getting 1.78Mbps VPN ON.
      Oh dear, not fixed after all.
        @ti-3426173 said in IS VPN with problem now?:
        I guess as a random someone who never paid anything for Opera I have little right to complain about anything in the first place...
        However as it currently stands I can no longer use Opera with the HEAVY DOWNGRADE of VPN in Opera 50.
        Today I was forced to update Opera since "VPN is no longer Supported" and what I got was horrible.
        Instead of being able to choose specific Countries USA, Netherlands, Germany I'm now resricted to continents. That would not be that much of a problem.... But the Speed of the VPN connection is bad joke... Simple sites are loading for ages... video streaming... lol! forget that!
        (OFC... I already tried alot to fix this aka antivirus, router, third party - no use)
        The main usage of my Opera was to avoid the strict region locks I have to suffer when using streaming provider such as Crunchyroll. Sadly - that's impossible now.
        If that's not going to be fixed I'll have to look for another solution and there's little reason for me left to use Opera at all. 😕
        Just why?....
        Use Firefox with HOXX VPN addon and the IP leak stopper addon.
        For free.
          cybrsaylr last edited by
          Opera VPN is working great right now! I'm in NY USA and selected Americas and got a NY City server giving me great speeds all around. Videos are even playing well!
          Hope it lasts!
            Opera free VPN provides these options: Optimal location (default), the Americas, Europe and Asia.
            Unfortunately the option for the "Asia" do not work as it should work.
            When I choose "Asia" location, it connects to a Germany IP adress (so an Europe country and not an Asia country): https://i.imgur.com/2uMWgVw.png
            Optimal location works great: https://i.imgur.com/QbX5rbP.png
            Americas works great: https://i.imgur.com/McD56sZ.png
            Europe works great: https://i.imgur.com/ZNbYHgU.png
            And please increase the bandwidth of Opera's VPN servers. Previously, when supplied by SurfEasy LLC the bandwidth was much faster (and better)!
            Specs: Opera 50.0.2762.58 stable in a Windows 10 Pro computer
              ? ? 2 Replies Last reply
              A Former User @Guest last edited by A Former User This post is deleted!
                vpn keeps disconnecting for me , is there any solution to this. cause the main i used opera is for the vpn nad what is the point of having a vpn if it will disconnect and reveal your ip anyway
                  @chocolate888822 said in IS VPN with problem now?:
                  I noticed the same issue with some sites. I thought I was getting greatly improved performance when running speedtest and then realized the VPN was flapping.
                  Also, I'm under the impression that Opera's VPN still suffers from the WebRTC IP leak and that obfuscating the IP address isn't reliable.
                    ? acidinmyfridge 2 Replies Last reply
                    that's because it does.
                    • acidinmyfridge
                      acidinmyfridge @Guest last edited by
                      @cbrown72701 currently trying ScriptSafe addon to prevent such things.
                      haven't tried uMatrix yet
                      @chuchkyschild are you using any of these addons? if so, are you pleased with the results?
                      You think you know, but you have no idea.
                        A Former User @acidinmyfridge last edited by A Former User
                        safescript is like noscript for firefox and won't have any effect on WebRTC IP leak. i'll checkout umatrix and let you know what i think.
                          @chuchkyschild said in IS VPN with problem now?:
                          safesript is like noscript for firefox and won't have any affect on WebRTC IP leak. i'll checkout umatrix and let you know what i think.
                          i see umatrix is another script blocker so won't have any affect on WebRTC IP leak.
                          • acidinmyfridge
                            @chuchkyschild thanks mate. with ScriptSafe enabled, i checked on ipleak.com/full-report/ and yeah no effect on WebRTC IP leak.
                            i was looking at these addons WebRTC Protect, WebRTC Control. will try them out.
                            As for now, i use uBlock Origin, pricavy badger, disable WebGL
                            @rudrick were you using uMatrix? if so, does it prevent WebRTC IP leak?
                              @acidinmyfridge just added webrtc protect and privacy badger and ran the test and passed.
                                @pinportal what happened? the other options dissapeared americas is the only one left
                                  is vpn working for any of you currently? cause ican't connect to anything and except for americas all the other options have dissapeared
                                    @chocolate888822 is right the vpn is now worst it's ever been.
                                      I'm in New York and when selecting Americas NY City last couple days VPN was working decently. Today VPN is running very erratic and slower than ever.
                                        It's well after the Holidays and the Opera VPN performance is worst than ever. It can't even maintain a reliable connection to the forum; keep getting pop-up messages advising of a disconnect. From the forum discussion, it appears that many are abandoning the browser; it seems that Opera has really shot-itself-in-the foot!
                                          alanchippy @Guest last edited by
                                          Have now got used to being ignored by Opera staff. What a shame as it was a good browser which seemed to be responsive to its users. Badly disappointed as Opera still have not commented and it shakes my confidence in how Opera will continue to have the confidence of its users.
                                            Using win 10, 64 bit & Opera 50.0.2762.58 (PGO).
                                            I'm located in TX and I have set the VPN location to the Americas. It connects alright. So far, so good.
                                            However, when I access US websites (e.g Huffport or NYT, etc., I see ads in all kinds of languages. Some in Norwegian, some in Swedish, some in French, every now and then I see one in Russian.
                                            When I'm on Amazon, trying to order an item, I get messages that this item cannot be shipped to Sweden or Norway, etc.
                                            Doesn't look like VPN has been fixed, or is it just me?
                                            Ed
