    IS VPN with problem now?
    Opera for computers
    68
    219
    326530
    • acidinmyfridge
      acidinmyfridge @acidinmyfridge last edited by
      @acidinmyfridge edit: checked their website, looks somewhat dubious to me. pricing for premium only says from 1.99$ and nothing else.
      You think you know, but you have no idea.
        zalex108 last edited by
        @acidinmyfridge
        You can try it on a Test profile without any personal information.
          A Former User @acidinmyfridge last edited by
          @acidinmyfridge it is free with unlimited bandwidth, but there's not a version for Opera as far as I can see. I use it with FireFox and Chrome and it doesn't seem to impact performance too badly. It does allow WebRTC IP leaking, though, so if you're concerned about that, you'll also need an add-on for that.
            acidinmyfridge zalex108 2 Replies Last reply
            @chuchkyschild Right you are in they broke something that was working. From what I gather, it probably done as a cost saving and/or control measure to bring the VPN services inhouse rather than outsource it. It just seems to me they either were OK with degrading the service or they didn't realize how complex and costly it was going to be to create and support a well performing VPN.
              blackbird71 1 Reply Last reply
            • blackbird71
              blackbird71 @Guest last edited by
              @cbrown72701 You seem to assume there's a single "they" involved in this. In any typical business, there are multiple "theys" within the organization, each with its own point of view and resources, with one senior-level "they" who actually balances the option tradeoffs and makes the final decision that puts things all in motion. The other "theys" then have to do the best they can, within the time/resource limitations at hand, to eventually try to make it all work. It doesn't always unfold with elegance.
              • acidinmyfridge
                acidinmyfridge @Guest last edited by
                @cbrown72701 that is not an issue, can get a chrome extension to work in Opera. with this addon.
                looking at chrome extensions which prevent IP leaking, can't find IP leak stopper, looking at this chrome extension instead.
                still not convinced of this HOXX VPN/proxy.. will research it a bit more.
                  zalex108 @Guest last edited by zalex108
                  @cbrown72701
                  Search for Install Chrome Extension at Opera Addons, then you'll be able to use mostly all Chrome extensions on Opera.
                  Already said. 👀
                    A Former User @blackbird71 last edited by
                    @blackbird71 not wanting to start a flame war or anything or pick at too many nits, especially since the bulk of what you said is correct, but "they" is a plural pronoun and was used intentionally.
                    • blackbird71
                      @cbrown72701 said in IS VPN with problem now?:
                      Understood. But "they" is often used as a collective singular to describe a company or department or organizational block which consists of multiple individuals. It's in that context that I interpreted what you wrote and in which I responded. The "they" of Opera probably didn't in totality make the decision to sell the SurfEasy operation... it was the "they" of their board of directors (or equivalent); hence the "they" of the development group may have had only limited say in the matter, but were left with the responsibility of trying to make the necessary design adjustments to the browser's VPN capability.
                        Connection via VPN is very slow in the new browser (50). Will you improve speed?
                          After several updates, the VPN stopped working. I wanted to know why?
                            fazerya @leocg last edited by
                            @leocg
                            Hi !
                            It sucks !
                            Sorry but the VPN option have a problem. Now, with a option "bests results" (meilleurs emplacements) or Americas, (for it's for Canada), nothing works at all.
                            And on the player's screen, when I want to see a vid, I can read "Conformément aux droits de diffusion, le contenu sélectionné n'est pas disponible dans votre pays." (I'm sorry I' from Belgium and I talk French)
                            Like other people I'm very disapoint.
                            I have the lastest version of Opera (50.0.2762.45 (PGO))
                            Someone can help us ?
                            Many thanks and sorry for my english
                              cybrsaylr last edited by
                              Using Opera 49.0.2725.64. Last couple days, at least, been getting decent speeds using Opera VPN. Videos still play balky though but better than last week. Hopefully they are improving things. Been using Missouri USA and Columbia locations which have been giving better results than the others.
                                @acidinmyfridge
                                You could also change DNS to those of OpenNic. And if you will, you can setup DNScrypt.
                                In your router, remember to block all ISP DNS, email them (or search) for full list.
                                https://www.opennic.org/
                                https://en.wikipedia.org/wiki/DNSCrypt
                                https://simplednscrypt.org/
                                  acidinmyfridge 1 Reply Last reply
                                • acidinmyfridge
                                  acidinmyfridge @Guest last edited by acidinmyfridge
                                  @rudrick will check out OpenNic nods
                                  was asking about that HOXX proxy simply out of curiousity ^_^ always interesting to see what other people use.
                                  currently, i am using this free vpn extension together with extensions like this and this. so far so good, works quite well.
                                  And i was looking at ScriptSafe. Haven't gotten around to try it out yet though.
                                    @acidinmyfridge
                                    ^That seems to be the fastest of the VPN's. Heck I could just switch to Vivaldi - and have my browsing with split screens, web panels, etc etc etc etc etc(!)
                                    I find uMatrix good - the developer of that ext (also uBlock Origin) is very trusted person among circles.
                                    *** ublock origin also has a "hard mode" which it then basically is umatrix.
                                    • acidinmyfridge
                                      @rudrick i'm using Vivaldi too. and i'm very fond of it. so customizable!
                                      tab stacking! 😃 so neat! Wondering if they're gonna implement VPN as well.
                                      also using uBlock Origin for a few weeks now. i quite like it. Haven't tried uMatrix yet, but it's on my list 🙂
                                      • blackbird71
                                        blackbird71 @acidinmyfridge last edited by
                                        @acidinmyfridge said in IS VPN with problem now?:
                                        ... i'm using Vivaldi too. ... Wondering if they're gonna implement VPN as well. ...
                                        If they do, it will be a good while from now. They have their hands full just developing the features they've been promising, plus they don't have the server farm/portals to support a VPN (or the cash flow to rent it).
                                          Vivaldi is not looking to VPN.
                                          I talk with the devs sometimes, they are quite nice. I wish they would open source that Tab Stacking of viv 🙂
                                          • acidinmyfridge
                                            @rudrick @blackbird71 oh well, even if they won't implement a VPN.. I think the VPN extension i am using is fairly decent and a good solution.
                                            Yes, that'd be great if they'd open source the tab stacking 🙂
