    Number appears in top left corner
      Just installed v48.0 on an older Windows 7 desktop and I have a blocky looking number in the top left corner that changes as the mouse is moved over different items. How can I get rid of this?
      Tried to upload a small screen capture but I don't seem to have that priviledge.
      [0_1509001374350_Blocky_Number.PNG](Uploading 100%)
      • amatczak
        amatczak Opera last edited by
        Can you try again with the upload? If the file is smaller than 2 MB it should work.
          Top left corner? Inside the page, near the menu button, etc.? Or not even inside Opera? (You may want to move the window to see if the number moves with the window.)
          If it changes as the mouse moves over items, then it sounds like some website debugging tool - but not one I recognize. Though if it is actually not in Opera's window then it isn't part of Opera and is caused by something else on your computer.
          • amatczak
            Does it, by any chance look something like this (numbers might be yellow)?
            FRAPS
              amatczak - Yes thanks. The computer does have fraps on it. Stop fraps and the numbers are gone.
              On my screen the number always appeared over the top left corner of the Opera window whether full screen or in a window.
