    INSTALLING problem and some WEBSITES stopped starting at 6 January 2017
    Opera Mini
    26912
      mbaluta last edited by
      I suspect that your mobile operator broke some rules that allowed free Opera Mini and you should contact with Maroc Telecom first. Anyway you can try to install older client: http://ftp.opera.com/pub/opera/android/mini/20.1.2254.110627/operamini.apk and check if it works.
        jqmeskoun last edited by
        @mbaluta I didn't got exactly what you mean , but I tried that opera mini , it still same problem with it
        I sent to you a message in Facebook , could you please answer me there , thanks
          But now I'm using version 20.0.2254
          Current version is 21. You should use it.
          Not yet , it still same problem I can't access with data mobile
          But you was able to access using wi-fi, right? So it means that Mini can access the site.
            what the point of using last version if all versions using same proxy server !!
            just I want to know is the problem from mobile operator or the opera mini proxy server
              Security? New features?
              I guess you already answered it yourself.
                yes , you are right but those things I'll use it when there is no problem
                I'm really confused with this , if operator is the reason , how they did that , i mean how they stopped something from working with just one browser Opera mini ? , it means that they blocked the opera mini from there own service , it's something not possible , because opera mini us i know have too much proxy servers , which means there is some proxy server or a APN settings that can be help me to solve this , i'm a right ?!!
                  They can have blocked the server.
                  They don't need to block all servers. Also, if the servers names has a pattern, it shouldn't be that difficult to block them.
                  Don't know.
                    nerv2 last edited by
                    The last one may have some extra permissions, I didn't get further either. 😉
                      @jqmeskoun You may use a VPN or something which affects ISP footprint so try Opera Mini 7.5 via http://m.opera.com/cn/en Ginko flavor.
                        @nerv2
                        Unfortunately , it's same thing with that version , but thanks
                          @jqmeskoun:
                          seems your provider has locked you out from accessing opera's server ip adress blocks.
                          your country is not exactly famous for free speech etc, but give uc mini a try, maybe their tunnel is still open.
                          good luck, and let us know.
                            in addition to this small problem , this damn provider blocks more websites too , and VOIP service , everybody are complaining , anyway .
                            I'll try with uc mini , thanks
                              @cubot by the way is there any way to change the IP of opera proxy server in just opera that I use , just to solve this 😕 !?
                                by the way is there any way to change the IP of opera proxy server in just opera that I use , just to solve this !?
                                Nope.
                                  @jqmeskoun:
                                  leocg is correct.
                                  but you can root your phone and use orbot (from fdroid) as an android client for the tor network to circumvent internet restrictions.
                                    @cubot could you please explain how that orbit work , and is it certainly can work with me ?
                                      @jqmeskoun:
                                      1. read about tor
                                      https://www.torproject.org
                                      1. for orbot app first download and install the f-droid app from
                                      https://f-droid.org
                                      and you'll find orbot explained in their repository ready for download.
                                      if your phone is not rooted, you might have to use the lightning browser though; and tor is awfully slow and heavy on your data rate.
                                      or try opera max with any other browser than mini instead, maybe thats not blocked (yet).
                                        actually i did not solve this yet 😞
