    How to delete yandex from speed dial (Russia)
      alexqueue last edited by
      Hi. How can I delete yandex search engine from speed dial? (my location is Russia). http://postimg.org/image/ja1su9q3p/
      I want to use google. How can I install it?
        I changed file AppData\Roaming\Opera Software\Opera Stable\Local State
        from
        "country": "RU",
        "country_from_server": "RU",
        to
        "country": "US",
        "country_from_server": "US",
        and i got google search engine! http://postimg.org/image/9oplit875/
        is there other way to change it?
          Not that I know of ...
            vinnikovsa last edited by
            Dear support,
            I cant understand why Opera decided that users from Ukraine should use YANDEX????
            May be check statistics of usage???? Especially because Yandex is RUSSION resource, and searching in another way.
            Of course i can change manually, but that is owfull to change it for all users where i am working. Most users in Ukraine will never use Yandex search (exception if they dont know how to change it).
            Implement selection/configuration as it was in previous version, or change it please to GOOGLE in UA zone in next releases.
            Regards,
            Sergii V
              No developers here mate. Just other users. Your best bet is to post in the comments of the Opera blog after they put out a new release.
                Go to settings, enable the power user mode, and check the option "Hide the search box in Speed Dial". I guess it may work.
