    Sync same Speed Dial on every device
    56
    104
    135819
      @leocg
      Only ones EVER in this forum that want separate speed dials are Moderators and Opera Software employees. No one - zero, nada, nobody wants different ones. Speed dials are start page bookmarks and they should be in sync with anything sync'ing them.
      If not - there should be an option. and given Opera's history of "more options the better", the only thing to think, is there must be some weird programming barrier or laziness that keeps them from giving the users the #1 request since speed dials were put in the software.
      Reply Quote 5
        @btabke Those who want different speed dials on different Opera installations already have it, so they don't need to come here or anywhere else to ask for it. That's why you don't see that many people here saying that they want separated speed dials.
        More options = more code = more bugs.
        Reply Quote -1
          R 1 Reply Last reply
          rooneyandmuldoon @leocg last edited by This post is deleted!
            rooneyandmuldoon last edited by
            @leocg said in Sync same Speed Dial on every device:
            No effort to provide the most important and requested option (i.e. syncing speed dial on all devices)= no users
              leocg Moderator Volunteer @rooneyandmuldoon last edited by
              @rooneyandmuldoon Most important for who? Most requested by whom?
                yes! at least for desktop devices!
                  scientusiasta last edited by
                  Nooo I've just found out it is not possible to have the same speed dial on all devices. ๐Ÿ˜ž
                  I'm one of those who need the very same speed dial on desktop pc and notebook. So disappointed.
                  Reply Quote 3
                    zalex108 1 Reply Last reply
                    zalex108 @scientusiasta last edited by zalex108
                    @scientusiasta said in Sync same Speed Dial on every device:
                    https://forums.opera.com/topic/8987/sync-same-speed-dial-on-every-device/50
                    "You cannot know the meaning of your life until you are connected to the power that created you". ยท Shri Mataji Nirmala Devi
                      @btabke
                      I don't buy at all "everyone wants different speed dials on every device". That's bs. Nobody does..
                      I do. And I am not part of Opera software in any way. But I suppose that it was too much of a trouble to read the whole thread. I guess you are too busy and too important.
                      What's the real story here? Is this too big of an issue for Opera Soft to program ? 800 billion options in opera and they can't program the #1 request by users of all time?
                      Where is this a #1 request?
                      What are "start page bookmarks"? Could you point to the definition? Should be sync? Says who?
                      You have a folder within the bookmarks? What else do you want? Too lazy to copy a couple of tiles? Or you have a weird psychological barrier to do that? Maybe learned that mummy needs to do everything for you?
                      I don't want that behavior and I think it is a disaster. Making speed dial synced as a separate option would be the only acceptable solution, for my point of view.
                        *from my point of view ๐Ÿ™‚
                          I think I may finally have the answer. Duck Duck Go.
                            rooneyandmuldoon last edited by This post is deleted!
                              @leocg leocg, I am truly stunned to see how unprofessional you are, as a moderator. You represent Opera directly to your consumers, and I find you to consistently be rude and antagonistic in the forums, both to me and to numerous other poor souls looking for answers and trying to make suggestions that they feel would make the browser that they have chosen, and obviously have allegiance to, better.
                              Most recently, I submitted a suggestion that it would be nice if one could put subfolders into folders. Your brusque response: shouldn't be in forum, case closed. What? Thanks for caring.
                              It seems that you would rather abuse your users than accept well-intentioned and usually great suggestions. You are a bully, and I can only assume that since Opera allows you to represent them that they must subscribe to your actions.
                              I am moving to a different browser (probably back to Duck Duck Go), regardless of the inconvenience to myself, and would suggest others offended by your behavior do likewise.
                              I am going to do my best to send this message to Opera administration, though I suspect, since they allow your behavior, that they won't want it. I would imagine that you will remove this, but at least hopefully you will see it.
                              Reply Quote 5
                                darthagnon last edited by darthagnon
                                I wish I had the option of 1 speed dial for both of my computers. I recently migrated PCs, and was startled to find that my speed dials had not appeared; it was only after poking around that I found them under a speed dial thingy from my other machine.; I then copypasted them into my new PC's speed dial. Not a biggie, but a little annoying. Ideally, it would be the same for both, since I use both machines the same, and it makes bookmark sync look messy, with speed dial folders from old computers I don't use anymore appearing. I keep my Work Only and Home Only and School Only sites in separate folders, anyway, so I don't need multiple speed dials. This feature request gets an upvote from me.
                                Reply Quote 3
                                  Post in the correct forum.
                                  Moderators will deal with messages that violate the forum rules by closing threads or deleting or editing messages
                                  https://forums.opera.com/rules
                                  You posted on the wrong forum, so your topic was closed. And your reply here violated the following:
                                  Stay on topic. Don't hijack other people's threads.
                                  And if you do it in other forums, you must probably will be banned.
                                  By the way, moderators don't work for Opera or represent it in any way.
                                    zalex108 @darthagnon last edited by zalex108
                                    @darthagnon
                                    There is a way to achieve it.
                                    Look for 1 SpeedDial on 2 Devices Thread, - can be found on my Topics -.
                                      I can easily live without this feature. It would be nice, but I can just copy/paste the speed dial every now and then.
                                      Unfortunately copy/pasting speed dial is something a little too complex to communicate to clients. People want now days a flow of using their devices, from home, to office, to phone while commuting and then back at home (PC/mac/tablet). Lack of one-speeddial between devices is, from average users point of view, something that is not a sales point for Opera in "tech enthusiast" crowd, for whats-a-browser crowd it most likely is. But which crowd is more likely to use Opera?
                                        @zalex108 said in Sync same Speed Dial on every device:
                                        You just need to copy the SD bookmarks from Other Speed Dials to the SD of your other machine.
                                        BTW, a switch or a selector to select the behavior would be nice.
                                        ย
                                        +!. Simple make it a choice. Toggle mutli device sync yes or no. Each device can opt out of the multi-sync.
                                        Reply Quote 3
                                          Q 1 Reply Last reply
                                          I have found a solution to select any one of the "Other Speed Dials" as the default.
                                          1. Go to help->about and copy the profile path.
                                          2. Close the browser
                                          3. Locate the file "Bookmarks" in the profile path and make a backup copy.
                                          4. Edit the file using a text editor and search for the text "speed_dial_root_folder_guid". You will find something like this:
                                            "id": "121",
                                            "meta_info": {
                                            "speed_dial_root_folder_guid": "C362534A-560F-4370-B7CC-6E11CA38A54F"
                                            "name": "DESKTOP2",
                                          5. Now CUT the entire meta_info section including the comma at the end, that is everything between the "id" and "name" lines.
                                          6. Search for the name of the speed dial you wish to select and paste the meta_info between the matching "id" and "name" lines.
                                          7. Save & open browser.
                                            I just started using Opera, because i like design of this browser. But after few days I found, that it cant sync speed dial on devices ๐Ÿ˜ž
                                            That is reason, why I have to go back to use Maxthon browser, which can do that.
                                            Let me know if this funion will be availabe and I will be happy user of opera.
                                            Reply Quote 3
