    Alt+Enter doesn't work for me...
    opera developer
      sham69 0 last edited by
      When I press alt+enter in the address field, the expected result would be that opera opens the entered address in a new tab, but that doesn't happen (for me), is there any way to restore this functionality, I know it worked before (some versions ago...)
        leocg Nearmelab 3 Replies Last reply
        leocg Moderator Volunteer @sham69 0 last edited by
        @sham69-0 Opera One (regular Opera), Opera GX or Opera Air?
          @sham69-0 Works here on 126.0.5750.43
          • Nearmelab
            Nearmelab @sham69 0 last edited by
            Welcome @sham69-0,
            Go to Opera browser settings, search for Duplicate tab and type your usual shortcut Alt + Enter.
            Join your productivity.
              ryanemmunal last edited by
              This behavior was changed in newer Opera versions. Alt + Enter opening a URL in a new tab is no longer supported in the address bar, especially in Opera Developer builds.
              Current alternatives:
              Use Ctrl + Enter to add .com (same tab)
              Press Ctrl + T, then paste the URL and hit Enter
              Middle-click (mouse wheel click) on the address bar after typing the URL
              Right-click → Open in new tab
              Use Ctrl + Shift + Enter (works in some builds)
              At the moment, there is no built-in way to restore Alt + Enter behavior. The only workaround would be a keyboard remapping tool or extension, but Opera does not officially support this shortcut anymore.
                leocg Moderator Volunteer @ryanemmunal last edited by
                @ryanemmunal ALT Enter still works here in Opera One Developer and Stable, Opera GX and Opera Air.
                Also works in Opera Neon.
