    Opera will not load
    1666
      nihaoken last edited by
      I don't know what to do...
      I started using Mozilla because I am no longer able to use Opera. Every time I click and open Opera, the program appears to open and the tabs from an old session appear to be loading, but the loading stalls out there and I am not able to do anything with the browser except right-click on the taskbar and force close. I've already uninstalled and reinstalled with the same result. I can't check which version I have because the browser will not allow me to do anything except close. I am running windows 7 (64 bit). I am also running Malwarebytes and Kaspersky Internet Security.
      I appreciate any help you might be able to offer.
      Thanks!
        What version was it before? Was it an automated upgrade?
        You can right-click on the Opera icon on your desktop or wherever it is and choose "Properties", then click the "Find object" button there: you're supposed to get a folder opened with a file highlighted - that must be the launcher file, right-click on it and look for the "File version" item.
          Okay, I found the file version #: 27.0.1689.54
            Find your sessions.db file and delete it. It should be located in a directory that look something like this: C:\Users\youraccoutname\AppData\Roaming\Opera Software\Opera Stable Did that fix it?
              I deleted the session.db file...Now my tabs are gone, but the about:blank tab shows Loading...and the browser sits
                Interesting. Have you tried removing and reinstalling the browser?
                  leocg Moderator Volunteer last edited by admin
                  Maybe related to the issue discussed here?
                    Yes, I did try reinstalling. I followed the link and tried that...didn't help either...?
