    Having problems with SoundCloud shortcut audio
    soundcloud audio help side bar player shortcuts
    • I
      issapierre last edited by
      When I try playing audio from the SoundCloud shortcut I have on the sidebar the audio sounds far away, but when I actually go on the website it sounds perfectly fine is there a way to fix this if not I am okay having to search up the website as stated. But it does make the browser more cleaner with less tabs for me personally that's why.
        The player sidebar just loads the SoundCloud website, so it should be any difference compared to SoundCloud in a tab and it's not for me in Opera 112.0.5197.25 64-bit on Windows 11 23H2.
        Now, if you have an audio/volume/eq extension installed at the URL opera://extensions, it might not work for the sidebar, which could cause the difference. If that's the case though, the sidebar would be the original, non-enhanced sound.
        I guess you could test with "Use graphics acceleration when available" off at the URL opera://settings/system to see if that fixes it.
          A Former User @issapierre last edited by A Former User This post is deleted!
