    Problem logging into PNC Bank
    10770
      chawoobie last edited by
      I've been having a recurrent problem logging into the PNC Bank with Opera. I have used Opera since version 1, and I have had few problems logging into most sites. However, in the last week or so, when I try to log in the following message pops up: "Service unavailable
      Online Banking is unavailable right now. Please try again later or contact us."
      I can log into PNC with Chrome, DuckDuckGo, Edge, or Firefox with no problem. I can also use a User-Agent with Opera and log in, so it doesn't seem to Opera, per se, that is the problem.
      PNC says they don't support Opera, but I have been using with their site for year with no problem,
      Any thoughts?
        leocg ? H 3 Replies Last reply
        leocg Moderator Volunteer @chawoobie last edited by
        @chawoobie So if you change the user agent, you are abe to login?
          C 1 Reply Last reply
          chawoobie @leocg last edited by
          @leocg Yes. I can log in using a user-agent, or any of the other browsers. I even tried several times to uninstall Opera using Revo uninstaller, then reinstalling, but problem persists.
            @chawoobie So the site is deliberated blocking Opera.
            You can use the report a site problem or the report a problem tools, in Opera, to report the issue and, maybe, Opera will implement a workaround.
              @leocg Thanks. I did that yesterday.
                Still unable to log into PNC bank website with Opera 111. I can use other browsers and use a user agent switcher to use Opera. Bank says it isn't their fault. I don't know. Have used in the past without problems, even though Opera isn't in their list of approved browsers.
                  @chawoobie The bank needs to stop blocking Opera.
                    @leocg Problem Solved! After pestering PNC bank repeatedly on X, they finally stopped blocking Opera!! I can now log in just fine without using user-agents or a different browser.
                      M 1 Reply Last reply
                      A Former User @chawoobie last edited by This post is deleted!
                      • H
                        hamdanaslam88 Banned @chawoobie last edited by
                        @chawoobie It sounds like the issue could be related to how Opera is interacting with PNC's site, especially if you're able to log in using other browsers without a problem. Since PNC doesn't officially support Opera, they may have made updates that inadvertently affect compatibility with that browser.
                        You mentioned using a User-Agent switcher, which suggests the issue could be how Opera is being identified by PNC's site. If using the User-Agent works, it might be worth continuing with that for now. Additionally, clearing your browser cache, cookies, or trying Opera in incognito mode might help if there are any residual conflicts.
                        Another option would be to ensure your Opera browser is fully updated. Sometimes, specific website scripts or settings don’t mesh well with outdated browser versions.
                        Hope that helps!
                          mawagner0 @chawoobie last edited by
                          @chawoobie Although PNC Bank may have lifted their block on Opera for you last June, I continue to have this login issue. Are you still able to log in? If so, do you recall who or what department you talked to at PNC?
                            chawoobie @mawagner0 last edited by leocg
                            @mawagner0 Sadly, no! Chrome still works, DuckDuckGo, Firefox, Brave but not Opera!
