    My flow Not working
    my flow
    15
    37
    27886
      denjohan last edited by
      Got my Opera on Android automatically updated to 81.5.4292.78980 and tried again, this time after confirming that I'm logged in on both machines and that sync is on. Clicking the flow button in Opera for Windows (not updated since last post) prompts me to connect the phone although I'm already logged in and synced on both machines. On the phone, I was prompted again to follow the instructions on the other device (Windows) with the unchanged confirmation code shown.. This time, on Windows, I'm not getting the spinning wheel but a message "Congratulations! You're now logged in. What would you like to do?". There are two buttons; "Synchronize" and "Manage your subscriptions". I clicked the former but nothing happened. After a while got "failed to connect" on the phone. It also turned out that, without notice, sync had been switched off and I had been logged out. Looks like a problem on the Windows version since I was not logged out on the Android version.
        E 1 Reply Last reply
        falone last edited by
        Eventually, it works for me now. I didn't do anything additional, just keeping my Android and PC browsers updated and now Flow works fine for 3 deviced.
          I turned off two-factor authentication and now I can see the flow.
            F E 2 Replies Last reply
            falone @denjohan last edited by
            @denjohan said in My flow Not working:
            BTW, same here! I turned two-factor authentication too
              Elias-155 last edited by
              I have had this exact problem for about a year now and I am unable to get my flow working!!!
              please fix this problem opera!!!
                erehwon2 @denjohan last edited by
                @denjohan Same - this is what happens to me, though I think I get different confirmation codes each time.
                  erehwon2 @falone last edited by
                  @falone Are you just trying to make the rest of us jealous? 😞
                    @denjohan I did try this a week or so ago and it didn't help. Maybe I need to try this again.
                    Have you tried turning 2FA on again? (I remember having this problem with a Reddit app ages ago - turn off 2FA, log in on the app then turn it back on again)
                      RubTriangleRub @erehwon2 last edited by
                      @erehwon2 It works when you enter the full URL, https and all, for example example.com https://example.com.
                        erehwon2 @RubTriangleRub last edited by
                        @rubtrianglerub Do you mean the URL for Send to Flow? When I do it from my phone, I go to a web page and then select Send to Flow from the menu. I don't copy/type a URL at any point. When do you enter in a URL? Maybe I can copy your method.
                        Just tried again to connect my phone to My Flow and still getting the same issues?
                        • mathias87
                          mathias87 last edited by
                          Today I was able to connect my phone with Flow.
                          Maybe it's because of version [...] .68...
                            P 1 Reply Last reply
                            ppclarke @mathias87 last edited by
                            @mathias87 I just got it to work on my laptop. Maybe they listened after all.
                              A Former User @Mxmatt38 last edited by
                              @mxmatt38 said in My flow Not working:
                              I am trying to connect My pc and phone it used to work but stopped wen I scan the QR code it tells me to follow the steps on my screen and gives me a code to enter but I never get a screen on my computer to put the code in.
                              I am also facing the same problem, but no QR code shown there. I don't know why!
                                mathias87 1 Reply Last reply
                                rikazkhan7 Banned @Mxmatt38 last edited by
                                @mxmatt38 Make sure both devices are compatible with the application or service you're using.
                                Check if there are any specific requirements for the connection, such as both devices being on the same network or having certain permissions enabled.
                                • mathias87
                                  mathias87 @Guest last edited by
                                  @joshsiddle8 Connecting my phone to Flow was successful by going to www.opera.com/connect.
                                  The same code like shown on my phone was shown on my computer and it worked.
                                    My flow works!!!! You must install the new Update and then it works. 😉
                                      erehwon2 @Elias-155 last edited by
                                      @elias-155 On Windows 10 I'm on 109.0.5097.68. On Android I'm on 81.6.4292.79147 and these are the latest versions. And...
                                      It's worked!!!! 🎉 🎆 🎈
                                      The pin code came up on my phone and my desktop browser showed that code as well. The first time it ever has. All is well (hopefully)
                                      I hope it's now working for everyone.
