    Overheating and using significant energy
    Opera for Mac
      Cinnamonandme last edited by
      Opera One high energy consumption on my macbook M1 Air 2020.
      400+ in 12 hours, screenshot attached.
      Discharges quickly and overheats. Has anyone had a similar problem, please share the solution 😞
        M 1 Reply Last reply
        m6v10 @Cinnamonandme last edited by leocg
        @cinnamonandme Try Brave browser mate, seems like too many bugs in One
        • tesityr
          tesityr last edited by
          that is how browsers are, they are usually the most used program:
          https://forums.macrumors.com/attachments/p9hrsag684y91-jpg.2108468/
          note that the two highest apps are the browsers
          it is not something specific to Opera.
          you can try dusting out system, making sure fans are clear
          you can try opening the case and dusting inside, if you are not comfortable with that, take it in and they can dust inside. dust collection inside contributes very much to heat. do not block fans or put on rug or cloth, or too close to walls, etc. these placements block the fans output and the intake of fans too, which all cool the system
            C 1 Reply Last reply
            Cinnamonandme @tesityr last edited by
            @tesityr
            I actually don't have any fans or dust in my laptop XD.
            Thanks for the answer
