    How to set another search engine as default?
    Opera Browser
    search engine settings
      A Former User last edited by sgunhouse
      Hello,
      On settings I added new searching engine address. Now i want set this searching engine adress as default. But i can not. There not option to select.
      Can you help me?
      Thanks.
        S 1 Reply Last reply
        @ulviibrhm No, Opera only allows choices from the bundled search engines as default. At the time the idea was to prevent malware from setting a new search engine as default.
          A Former User @sgunhouse last edited by
          @sgunhouse thank you very much.
