    Is there a way to change opera gx speed dial thumbnails?
    6471
      I want to change it to a custom thumbnail I chose and wondering if there is a built-in way to do this and if there is a way to do it that is not built-in
        @severalpeople You can't use custom thumbnail but you can change the thumbnail.
          How do I change thumbnail
            Also, where is the thumbnail icon stored?
              @severalpeople As said many times, you go to the page, click on the heart icon at the right of address bar and choose a different image among the ones available.
                @leocg Yah I want a custom one tho, so considering there is no built in way to get custom icons, can I know where the thumbnail icons is stored?
                  diezi leocg 2 Replies Last reply
                • diezi
                  diezi @Guest last edited by
                  @severalpeople Hope it help you!
                  https://forums.opera.com/topic/43200/solved-customize-speed-dial-icons
                    @severalpeople In BookmarksExtra if I'm not wrong.
                      A Former User @diezi last edited by
                      @diezi That helped so much thanks!
