    Speed dials missing after an update
    Opera for computers
    speed dials update upgrade
    15
    34
    31971
      leocg Moderator Volunteer @Pebbles1980 last edited by
      @Pebbles1980 In Opera, at the bookmarks manager page as said above.
        @Pebbles1980 This one: https://forums.opera.com/post/218065
          Yep that worked. Thanks so much!
            As it says:
            I just updated to version 69.0.3686.77 and it deleted all my speed dial content
              spnoe last edited by
              After recently adding Opera to a new Linux OS, I find that if I login in and synchronize my Speed Dial, I lose those i have added previously and there is no way of adding speed dials.
              Any one had this experience and know of a way of enabling them?
              Thanks Steve
                sbratton last edited by
                Hi,
                Opera has auto upgraded to Version:69.0.3686.77 and all of my speed dials disappeared.
                I manged to recover by copying from another linked PC.
                Are there any other precautions I can take for future updates?
                Such as external backup of speed dials, how is best to do this?
                Thank you
                Steven
                  After the last update to version 69.0.3686.77, everything i added to speed dial is gone.
                    opera.png Easy solution - On the Speed ​​Dial page, right click on the page choose option bookmarks (above the history option) you should be able to see a new screen with your favorites. opera 2.png Because of this inconvenience and these poorly made automatic updates I am stopping using Opera. I hope this helps you
                      pnwfox last edited by
                      Re: Speed dials missing after an update
                      After the latest update my speed dials and all subfolders went missing. I had previously disabled the "Show Speed Dial Suggestions" and by re-enabling this feature my speed dial cards and folders were restored upon restart. Hope this helps anyone experiencing the same shock when opening Opera!
                        acts432 last edited by acts432
                        I found out today, that a significant part of my Speed dial folders are missing. I don't know when it happened or what action caused it.
                        I didn't find it in opera://bookmarks/ either.
                        Opera version 75.0.3969.171
                          Yep these are missing
                            A Former User last edited by This post is deleted!
                                vr51 last edited by
                                I've just spent an hour figuring out a solution. The problem is that Opera's 'Local State' file has become either corrupted or unsuited to the new version of Opera.
                                The solution
                                1. Close Opera. Close all running instances of the browser.
                                2. Browse to your local Opera profile folder. In Linux this is under /home/[username]/.config/opera/. I have no idea where this Opera folder is in Windows or Mac. You will need to look for it. I think someone mentioned it earlier in this discussion thread.
                                3. Make a backup of the above 'opera' directory. This directory stores all your personalisations of the browser and stores any saved sessions; then
                                4. Rename the file 'Local State' to 'xLocal State'
                                5. Restart Opera
                                6. Your Speed Dials should display again; if not, they will be stored in Bookmarks > Other Speed Dials and from here you can select and drag them back into Speed Dials.
                                If the above solution causes your browser to lose its settings, just close Opera and restore the backup you made of the 'opera' directory in step 2.
                                The problem is that the Local State file prevents the Speed Dials folder from loading. It is as though Opera looks in the wrong place for the Speed Dials data.
                                Hope this helps,
                                Lee
