    Suggestion: add "tabs marker" to speed up moving of tabs between spaces(in side panel)
      It's very difficult to copy every link to move tabs from space to another space. I suggest to make a marker(ico would be above spaces, in side panel), that will help you to mark transfering tabs. Than you should choice space which will claim that tabs
      I don't think, that my idea is the finest, but it seems that fast moving of tabs must be realized anyway
        Also it would be cool if click(by right button) on the link would propose to open link in one of spaces
          @Cogito both features already exist in 69 version, but disabled by default in flags (work in progress probably)
            @andrew84 , May you show where did you find thease flags
              @Cogito check opera://flags
                @leocg Cool, thank you!
