    Why does Opera running 9 processes by default
      I have only one tab opened .
      why do you need so many processes
      Very wierd.I don't remember opera being such.
        donq last edited by donq
        You can see those processes in Opera task manager (Shift+Esc; menu - developer - task manager). There are some Opera internal processes plus extensions always running.
          @harsha549 A simple research would have told you that this is how Chromium works: one process for each thing running. So there is a process for the browser itself, one for each tab, for each extension and so on.
          Check Opera task manager as mentioned above.
            Thanks @donq and @leocg will check it out.
