    I need thumbnails instead of site logos in speed dial
    2891
      manya-otto last edited by
      How can i turn on thumbnails for all my sites in speed dial?
        It depends what sites you're using in Speed Dial.
        Some domains, mainly the ones in the default SD I think, like Google and Facebook, only seem to produce a logo in the SD, and it doesn't seem to be possible to change that unfortunately.
        Other "normal" sites that you add should produce a thumbnail image of the page you saved into the SD.
          It is strange, some time ago (with older opera builds) i got full screenshot of page in speed dial. It is really important for me to save google picture search results on SD so i can see thumbnail of that search result. Isn't there really any way to force opera make a thumbnail?
            Don't know if it will help but try renaming the folder "resources" under Opera's install folder.
              Didn't work for me. Why is this such a problem, it is XXI century in the end? Why Opera developers doesn't let users to decide what they want and customize SD? 😕
                christoph142 last edited by
                Did you by chance turn on "Coast like Speed dial thumbnails" in opera:flags in Opera 24 Dev?
                If so, turn it off and reload each speed dial.
                  I'am using 22.0.1471.70 build of Opera and there is no such option. 😕
                    A Former User last edited by admin
                    Partner Speed Dials will preset images for all the pages of similar domain (e.g. twitter.com is a partner entry, if you add twitter.com/user it'll use the partner logo instead of thumbnail), there's no option or fix for that as of now. Unless you customize manually.
                    Stash is an alternative, but it has a very different usage pattern.
                      I see. The deal is that i prefer opera so even houswife or kid can use it easily. Okay we will wait till they implement this feature. Maybe. 🙂
