    [Solved]Changing instance search engine to Duck Duck Go
    • Z
      zendog last edited by leocg
      Hi,
      How do I access settings to enable me to change to instant search provider? This is the only thing preventing me from choosing Opera as my main browser.
      Thanks
        Instant search can't be changed, other than changing your locale. (That is to say, if you're in Russia it will be Yandex, here in the US it will be Google, etc.) Personally I turned instant search off and just use the address bar (which can be changed).
          Z 1 Reply Last reply
        • Z
          zendog @sgunhouse last edited by
          @sgunhouse
          Thanks for the reply. Yeah, that's the realisation I came to also.
