    [Solved]Opera Upgrade Problem.
      Hello,
      I can not update the Opera written "Checking for updates ..."
      Windows 10,
      how to fix it?
      I have only Defender turned off and further problem is, it's weird because Chrome as I enter and spr in settings is normally spr and written with current and what about the opera? Sour
      Reinstallation does not help, default settings 3x I did and nothing, I turned off the firewall, disabled the anti-virus, 3x restarted the computer, I removed cookies several times ...
      Other browsers normally work ... only this OperaNews
      Previously it was normally ...
      Help me because it irritates me ... but as a last resort I will install downloading from the heh site, but you know the settings were convenient - I entered spr and installed the same ...
      Only one question is what is the reason for this behavior? :>
      Can I install it on a SATA drive because it is currently installed on SSD.
        slytheringirl last edited by
        Have you tried checking to see if Opera is allowed in your firewall? Also check to see if you have opera_autoupdate.exe in your installation folder. It should be located in Program Files on your local disk. No opera_autoupate.exe causes it to fail when checking for updates.
          Try running the installer.
            Managed to! When installing exe. I chose not a "X" for only "all users of this computer" but a strange solution after the problem! Thanks for your willingness to help!
            Regards Cheerful
