    Keyboard shortcut for Speed Dial
      richinbcs last edited by
      I've just migrated to a new computer and am using 54.0. The ctrl-space key now loads a pop-up window to "search for open tabs." On my old computer (53.0) the same key combination brought me to the speed dial. Is there any way to change this or at least create a key-stroke combination to go to the speed dial?
        Hi @richinbcs, go to Settings (Alt+P) > Browser > Shortcuts > Configure shortcuts, find "Open and close search...", delete default shortcut (add other one if you want), scroll down to "Speed Dial", and add custom shortcut. You can also use the default one - Alt+Home.
          A Former User @richinbcs last edited by
          @richinbcs I set opera as default browser and on my key board I just press the home (with the planet icon) button and opera opens.
