    Mouse gestures and context menu problem
      norway174 last edited by
      The problem:
      When I hold down the right mouse button. The context menu opens.
      Blocking mouse gestures if I move the mouse over it.
      I can still use mouse gestures, to an extent. As long as it does not move over the context menu. Which is sorta hard to do.
      What should happen:
      When I hold down the right mouse button, the gestures circle should show up. Or if I hold and release, then the context menu should show up.
      This is the way it's been for years, up until yesterday.
      What I have tried so far:
      • Restarting.
      • Disabling all my extensions, then restarted.
      • Disable then mouse gestures option, then restarted.
      • And enabled again, and then restarted again.
      • Googling, I didn't find anything relevant to my situation.
      • Tried looking on the forums here if anyone else had the same issue. Again, didn't find anything relevant.
      Version: 52.0.2871.64 - Opera is up to date
      Update stream: Stable
      System: Windows 10 64-bit
      Any help would be greatly appreciated on this.
      And if there is any more info I could provide, then I'll do my best to supply.
      Thank you!
        leocg Moderator Volunteer @norway174 last edited by
        @norway174 Did you try checking your mouse buttons settings?
        And I may be wrong but I guess the gestures circle no longer exist since a while. You simply press and hold the right button and do the gesture.
          N 1 Reply Last reply
          norway174 @leocg last edited by norway174
          @leocg I didn't consider that. As it's still working as in intended for other apps/on the desktop.
          The context menu only shows when I release the right mouse button. Like normal.
          But I checked the settings, just in case. And I didn't find any option related to when the context menu should show on a right click.
          So I tested it to make sure, again. And now something else is happening. When I right click, and hold. The context menu appears, then goes away. Then when I release the right mouse button, it shows up. Like normal.
          So it appears this may not have been the correct place to post for help.
          Edit:
          So now it's back to the first way again. I really don't know what's happening here. It was also fine for a second. Even in Opera. I could use mouse gestures like before. But now it's back with the context menu again.
          And it's fine in other apps, and on the desktop.
            @norway174 Did you try un-installing and re-installing your mouse drivers?
            Does the problem happens with a clean Opera profile?
              @leocg So, I googled some more.
              And I found a tip I should probably have done from the beginning.
              Which is to try another mouse, and I did.
              I probably should have done that before I started re-installing my mouse drivers. xD
              Anyway, it is an old mouse. Served me well for years.
              So it's probably time to get a new one anyway.
              Strange it only happens in Opera, but it's probably only going to get worse. 😕
              Thanks for your help at least!
