    Opera 52: adobe flash adobe flash does not work anywhere
    34
    14209
    • A Former User
      @leocg Thanks i saw that post but it requires registration to some ad site which i am not prepared to do
      To OP what do you get on this flash check page
      https://www.whatismybrowser.com/detect/is-flash-installed
      I get
        @ceedee It's not the only link on the post, there are the Adobe ones too.
        • A Former User
          ahh I was looking at a diff post but interestingly
          when i click the adobe one i get the same thing as op
          it says click to enable flash but this does nothing unless you allow flash in the opera message at top under bookmarks bar which is hard to see and easy to miss
            @ceedee This is the expected behavior, except for the 'hard to see' part.
            • A Former User
              I have the same problem.
              The image in helpx.adobe.com doesn't give me an option to click to enable.
              https://prnt.sc/izwbz1
              Using whatismybrowser.com , it says that flash is not installed or not enabled.
              A page I can't properly see: https://prnt.sc/izwhps
              http://espinachio.mybrute.com/cellule
              • A Former User
                @leocg It is not hard to see per se just easy to miss it as your eyes are focussed on the click to enable flash box thats all. Not sure what happens if you dont click it either way does it then default to disallow maybe.
                  @hecatombe http://whatismybrowser.com/ says that I have Flash installed and on http://espinachio.mybrute.com/cellule, I see a 'click here to enabled Flash' message.
                  • fclstudio
                    fclstudio last edited by
                    Well after seeing that the "help" here did not work. I decided to look for it myself and I found it for my case.
                    I take a long history of trial and error that does not count, I'll just say the solution.
                    If you have started the session in opera with the synchronization activated, reset the synchronization.
                    Here: https://auth.opera.com/account/login/success
                    Uncheck the configuration synchronization option, in the configuration panel in the Browser section. Settings / Browser / Advanced configuration.
                    Reset the factory opera. Settings / Browser / Reset Opera.
                    Re-login with your opera account and synchronize again.
                    Enjoy flash xD
                    @hecatombe @robzs
                      robzs 1 Reply Last reply
                    • A Former User
                      @fclstudio
                      Well, thank you.
                      I don't use synchronization. After your post I did log in, reseted opera, and loged in again. And it did nothing.
                      But I tried a second time, and even with out relogin it works now. Now the image to enable appears, and clicking it enables flash.
                      It's fixed, ty.
                        For future reference, to test to see if you can at least get Flash running in a fresh, test Opera:
                        Download the Opera installer, launch it, click "options", set "install path" to a folder on your desktop, set "install for" to "standalone installation" and install. In that Opera, goto "Menu -> settings -> Websites -> Flash" and set Flash to "Allow sites to run Flash". Don't enable Opera Sync in this test Opera.
                        If that doesn't work, in settings in that test Opera, goto "Browser -> System" and uncheck "Use hardware acceleration when available" and restart that Opera to see if it helps.
                        If you're not certain you have Flash for Opera, goto https://get.adobe.com/flashplayer/ in Opera, uncheck "download Chrome" (and any other offers), click "install now" to download the installer, launch the installer, close Opera, install Flash and start the test Opera back up again and test some sites.
                        If it still doesn't work in the test Opera, you should look for something outside of Opera causing the problem.
                        • robzs
                          robzs @fclstudio last edited by
                          @fclstudio it's work,thank you!
                          I think my problem come to the folder "preferences" on the synchronisation .
                          • melzinharj
                            melzinharj last edited by
                            @fclstudio
                            thank you
                            that was the only thing that works here and I've been trying manage flash to work since Opera 49
                            • A Former User
                              But can I set that plugin to be enabled automatically?
                              Before there was a setting in flags to always enable now there is not.
                                leocg zalex108 2 Replies Last reply
                                @alexdc Nope, there's no such option anymore.
                                • A Former User
                                  A Former User @robzs last edited by
                                  @robzs I'm having the same problem. You ever find a fix?
                                  • sgunhouse
                                    Are both of you still using 52, or are you posting in a thread that isn't really the right topic?
                                      zalex108 @Guest last edited by zalex108
                                      @alexdc said in Opera 52: adobe flash adobe flash does not work anywhere:
                                      @badgirlwon2
                                      Despite it seems the new problems will be pushed out into another Topic:
                                      Look at this FlashPlayer WorkAround in the meantime.
