    Flash player does not work; can not be able.
    162
    213255
      @pedrosantospaiva How old is that site? When selecting View Source (from the main menu, they block the context menu) they have Javascript that includes code for IE4 and Netscape 4!
      Under the circumstances I tested the page in Opera 12.18 and in that case it sort-of works. But in a current version of Firefox it looks the same as in a current version of Opera - a background and a title.
        For https://www.internetpolyglot.com/matching_game (clicking play button and then speaker button next to word), I got it to work. In addition to the https://* and http://* flash exceptions, I had to install the addCSS extension and enable this block for the site:
        embed[width="1"][height="1"] {
            width: 6px;
            height: 6px;
        There's an embed element on the page at the top left that's set to 1 x 1 pixels. I found that Chrome and Opera block Flash elements that are smaller than 6 x 6. So, using the CSS to make it bigger works around that. And, one can then easily click it to get the "allow" toolbar (if the site's not already covered by one of the Flash exceptions you have).
        Similar CSS might help for other sites where the Flash exception list isn't enough. Would probably be better to also include a selector for a 1 x 1 object element. Of course, other sites might use different widths under 6 x 6 that you'd want to handle.
        Something to investigate on a per-site basis at least.
          The only way I could get Flash to work was to add the site to the exceptions
          0_1513185343280_Opera1.jpg 0_1513185362762_opera2.jpg 0_1513185384371_opera3.jpg
            I've been messing with the extension API to make an extension to do what adding https://*, http://* and file:///* does. It's just a simple background script of:
            chrome.contentSettings.plugins.getResourceIdentifiers(function(list) {
                for (var i = 0; i < list.length; ++i) {
                    if (list[i].id == "adobe-flash-player") {
                            chrome.contentSettings.plugins.set({
                            primaryPattern: "<all_urls>",
                            setting: "allow",
                            resourceIdentifier: list[i]
            This of course doesn't solve all the Flash problems, just like manually adding the protocol-based exceptions doesn't. But, an "Always Activate Flash" extension might be useful if it could also fix the remaining issues.
            Opera might even be able to add an internal extension like this to add an "always activate flash" option back. But, that's a long shot.
              bbildman @Guest last edited by
              @shahramop
              Of interest is the fact that when you go to that page:๐Ÿ’ฏ
              http://www.baronstrainers.com/cc/100001555295584_Giftsanddogs.html
              not only does it not display correctly, it also does not display ANYTHING when you right click on that page, I realized that because I was going to try to use the "User-Agent Switcher" on that page, but alas, a right click does not pop-up ANYTHING. I think this is MORE than anything about Flash
                zalex108 1 Reply Last reply
                zalex108 @bbildman last edited by zalex108
                @bbildman said in Flash player does not work; can not be able.:
                If you don't know how to enable it, use Enable right click, from Chrome store.
                "You cannot know the meaning of your life until you are connected to the power that created you". ยท Shri Mataji Nirmala Devi
                  Nothing happens on a right click in Firefox either!
                  What a very strange web page.
                  It produces nothing unless Flash is enabled, but even when I can see it I can't see exactly what it's supposed to do!
                  A couple of the entries at the bottom show what appears to be some sort of countdown.
                  Here is the source, if anyone can interpret it.
                  <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
                  <html xmlns="http://www.w3.org/1999/xhtml">
                  <head>
                  	<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
                  	<title>CC Dog Feed</title>
                  	<script src="json2.js"></script>
                  	<script src="jquery-1.9.1.min.js"></script>
                  	<script src="flyjsonp.min.fix.js"></script>
                      <script src="flXHR.js"></script>
                      <script src="checkplayer.js"></script>
                  </div>
                  <script type="text/javascript">
                   var message="Function Disabled!"; function clickIE4(){ if (event.button==2){ alert(message); return false; } } function clickNS4(e){ if (document.layers||document.getElementById&&!document.all){ if (e.which==2||e.which==3){ alert(message); return false; } } } if (document.layers){ document.captureEvents(Event.MOUSEDOWN); document.onmousedown=clickNS4; } else if (document.all&&!document.getElementById){ document.onmousedown=clickIE4; } document.oncontextmenu=new Function("alert(message);return false")
                  </script>
                  	<script src="timer.js"></script>
                  	<style>
                  		body
                  			color:#FFF;
                  			background-color:#000;
                  			font-size: 28px;
                  			font-family: "Helvetica Neue",Helvetica,"Heiti TC","Microsoft Sans Serif",Helvetica,Geneva,sans-serif;
                  		.error
                  			color:red;
                  		.pets_container .pet
                  			width:100%;
                  			height:100px;
                  		.pet_pic
                  			width:240px;
                  			height:100px;
                  			float:left;
                  		.detail
                  			width:auto;
                  			height:100px;
                  			line-height:100px;
                  			float:left;
                  		.on_duty
                  			color:#00FF00;
                  		.detail .val
                  			font-weight: bold;
                  		.feeding
                  			color:#FF0;
                  		.not_feeding
                  			display:none
                  		.p1
                  			background:url(1.jpg)
                  		.p2
                  			background:url(2.jpg)
                  		.p3
                  			background:url(3.jpg)
                  		.p4
                  			background:url(4.jpg)
                  		.p5
                  			background:url(5.jpg)
                  		.p6
                  			background:url(6.jpg)
                  		.p7
                  			background:url(7.jpg)
                  		.p8
                  			background:url(8.jpg)
                  		.p9
                  			background:url(9.jpg)
                  		.p10
                  			background:url(10.jpg)
                  		.p11
                  			background:url(11.jpg)
                  		.p12
                  			background:url(12.jpg)
                  		.p13
                  			background:url(13.jpg)
                  		.p14
                  			background:url(14.jpg)
                  		.p15
                  			background:url(15.jpg)
                  		.p16
                  			background:url(16.jpg)
                  		.p17
                  			background:url(17.jpg)
                  		.p18
                  			background:url(18.jpg)
                  		.p19
                  			background:url(19.jpg)
                  		.p20
                  			background:url(20.jpg)
                  		.p21
                  			background:url(21.jpg)
                  		.p22
                  			background:url(22.jpg)
                  		.p23
                  			background:url(23.jpg)
                  		.p24
                  			background:url(24.jpg)
                  		.p25
                  			background:url(25.jpg)
                  		.p26
                  			background:url(26.jpg)
                  		.p27
                  			background:url(27.jpg)
                  		.p28
                  			background:url(28.jpg)
                  		.p29
                  			background:url(29.jpg)
                  		.p30
                  			background:url(30.jpg)
                  		.p31
                  			background:url(31.jpg)
                  		.p32
                  			background:url(32.jpg)
                  		.p33
                  			background:url(33.jpg)
                  		.p34
                  			background:url(34.jpg)
                  		.p35
                  			background:url(35.jpg)
                  		.p36
                  			background:url(36.jpg)
                  		.p37
                  			background:url(37.jpg)
                  		.p38
                  			background:url(38.jpg)
                  		.p39
                  			background:url(39.jpg)
                  		.p40
                  			background:url(40.jpg)
                  		.p41
                  			background:url(41.jpg)
                  		.p42
                  			background:url(42.jpg)
                  		.p43
                  			background:url(43.jpg)
                  		.p44
                  			background:url(44.jpg)
                  		.p45
                  			background:url(45.jpg)
                  		.p46
                  			background:url(46.jpg)
                  		.p47
                  			background:url(47.jpg)
                  		.p48
                  			background:url(48.jpg)
                  	</style>
                  	<script>
                  		var revision = 44;
                  		function getURLParameter(name)
                  			return decodeURI((RegExp(name + '=' + '(.+?)(&|$)').exec(location.search)||[,null])[1]);
                  		function formatTime(second)
                  			if(second < 0) second = 0;
                  			return [parseInt(second / 60 / 60), parseInt(second / 60 % 60), second % 60].join(":").replace(/\b(\d)\b/g, "0$1");
                  		var uid = "100001555295584";
                          var uid2 = "100001555295584";
                  		var signature = "6f16a1f273489392d3c714cde5d0c9b6";
                  		FlyJSONP.init({debug: false});
                  function initFeed(pet_id, final_dinner)
                  	if(pet_id == 0) pet_id = 18;
                  	postFeed(pet_id, final_dinner ? 2 : 1,
                  		function check(data)
                  		if(data.error === undefined)
                  			initFeed(--pet_id, false);
                  		else
                  			data = data.error;
                  			var error_type = data.type;
                  			var error_code = data.code;
                  			if(error_type != undefined)
                  				if(error_type == 'pet')
                  					reportState(data);
                  					return;
                  				else if(error_type == 'revision')
                  					revision++;
                  			initFeed(pet_id, final_dinner);
                  	function(){initFeed(pet_id,final_dinner);}, function(){});
                  var pets = new Array();
                  var init = true;
                  var timer = new interval(1000, cooldown_tick);
                  var pet_count = 0;
                  function reportState(data)
                  	var pets_container = $('.pets_container');
                  	var raw_pets = data.pets;
                  	if(raw_pets === undefined)
                  		pets_container.html('Adopt Some Pets');
                  		return;
                  	raw_pets = raw_pets.adopted;
                  	var onduty_id = data.pets.equipped;
                  	var index = -1;
                  	var pet_count_new = 0;
                  	for(var p in raw_pets)
                  		if(raw_pets.hasOwnProperty(p))
                  			pet_count_new++;
                  	if(pet_count_new != pet_count)
                  		pet_count = pet_count_new;
                  		pets_container.html('');
                  		init = true;
                  	$.each(raw_pets, function(id,pet){
                  		index++;
                  		pet.id = id;
                  		if(init)
                  			pets[index] = pet;
                  			pets[index].id = id;
                  			var pet_view = $('<div />');
                  			pet_view
                  			.attr('class', 'pet')
                  			.appendTo(pets_container);
                  			$('<div />')
                  			.attr('class','p' + id)
                  			.addClass('pet_pic')
                  			.appendTo(pet_view);
                  			var detail = $('<div />')
                  			.attr('class','detail')
                  			detail.html('&nbsp;Level&nbsp;:&nbsp;<span class="level val"></span>&nbsp;' +
                  				'Loyalty&nbsp;:&nbsp;<span class="loyalty val"></span>&nbsp;' +
                  				'Cooldown&nbsp;:&nbsp;<span class="cooldown val"></span>&nbsp;<span id="feeding_indicator" class="not_feeding">(Feeding)</span>');
                  			pets[index].view = detail;
                  		else
                  			pets[index].level = pet.level;
                  			pets[index].loyalty = pet.loyalty;
                  			pets[index].cooldown = pet.cooldown;
                  			pets[index].pause = false;
                  			pets[index].view.find('#feeding_indicator').eq(0).attr('class','not_feeding');
                  		pets[index].view.find('.level').eq(0).html(pet.level);
                  		pets[index].view.find('.loyalty').eq(0).html(pet.loyalty + '&nbsp;/&nbsp;' + get_loyality_max(pet));
                  		pets[index].view.find('.cooldown').eq(0).html(formatTime(pet.cooldown));
                  		if(id == onduty_id)
                  			pets[index].view.addClass('on_duty');
                  		else
                  			pets[index].view.removeClass('on_duty');
                  if(init)
                  	timer.run();
                  init = false;
                  function cooldown_tick()
                  	for(i = 0; i < pets.length; i++)
                  		if(pets[i].level < 5 && !pets[i].pause)
                  			pets[i].cooldown--
                  			if(pets[i].cooldown <= 0)
                  				pets[i].pause = true;
                  				pets[i].view.find('#feeding_indicator').eq(0).attr('class','feeding');
                  					initFeed(pets[i].id,false);
                  			pets[i].view.find('.cooldown').eq(0).html(formatTime(pets[i].cooldown));
                  function flashHttpRequest() {
                  	return new flensed.flXHR({ autoUpdatePlayer:true, xmlResponseText:false, instancePooling:true});
                  function postFeed(pet_id,food,_success,_error,_complete)
                  	var feed_json = {"id":9,"signature":signature,"action":"feedPet","params":{"user":uid,"foods":[{"pet":pet_id,"food":food}],"revision":revision}};
                  	var flproxy = new flashHttpRequest();
                  	flproxy.onreadystatechange = flashLoading;
                  	flproxy.onerror = flashError;
                  	flproxy.open('POST', window.location.protocol + '//imabigfanof.criminalcasegame.com/bridge.php');
                  	flproxy.send('query=' + encodeURIComponent(JSON.stringify(feed_json)));
                  	function flashLoading(XHRobj) {
                  		if (XHRobj.readyState == 4) {
                  			var data = JSON.parse(XHRobj.responseText);
                  			_success(data);
                  	function flashError(errObj) {
                  		_error();
                  var tok = "827747197322044|fNGcdVL76lsmo7_bzkCk0DvZtZs";
                  var atk = '?access_token='+tok ;
                  function get_loyality_max(pet)
                  	if(pet.id <= 15)
                  		var LoyaltyCoefficient = [0,1,4,12,24,0];
                  		return (20 + Math.ceil(pet.id / 3) * 10) * LoyaltyCoefficient[pet.level];
                  	if(pet.id >= 16)
                  		if(pet.id <= 18)
                  			var LoyaltyCoefficient = [0,4,12,24,48,0];
                  			return (10 + Math.ceil(pet.id / 3) * 10) * LoyaltyCoefficient[pet.level];
                  		if(pet.id >= 19)
                  		return (Math.ceil(pet.id / 3) * 10 - 20) * LoyaltyCoefficient[pet.level];
                  		if(pet.id >= 34)
                  		var LoyaltyCoefficient = [0,1,2,6,12,0];
                  		return (180 + Math.ceil(pet.id / 3) * 10) * LoyaltyCoefficient[pet.level];
                  		$(document).ready(function()
                  $.get('https://graph.facebook.com/'+uid+atk,
                  			function(data) {
                  							//uid = data.id;
                  				signature;
                  				initFeed(18);
                  				$('#name').html(data.name + ' : Alimentacao de Animals');
                  				//uid = data.id;
                   $.get('https://graph.facebook.com/'+uid2+atk,
                  			function(data) {
                  							//uid = data.id;
                  				signature;
                  				initFeed(18);
                  				//uid = data.id;
                  </script>
                  <script language=JavaScript>
                  var message="";
                  function clickIE() {if (document.all) {(message);return false;}}
                  function clickNS(e) {if
                  (document.layers||(document.getElementById&&!document.all)) {
                  if (e.which==2||e.which==3) {(message);return false;}}}
                  {document.captureEvents(Event.MOUSEDOWN);document.onmousedown=clickNS;}
                  else{document.onmouseup=clickNS;document.oncontextmenu=clickIE;}
                  document.oncontextmenu=new Function("return false")
                  </script>
                  </head>
                  <BODY LANG="fr-FR" BACKGROUND="bg.jpg" DIR="LTR" STYLE="background: url(bg.jpg) scroll">
                  	<div class="main">
                  		<div class="header">
                  			<div>
                  <form method="get" action="?">
                  <br>
                  </form>	</div>
                  		<div id="name"></div>
                  		</div>
                  		<div class="pets_container">
                  		</div>
                  	</div>
                  	 <div class="footer">
                  </a>
                   </div>
                  </body>
                    burnout426 Volunteer @burnout426 last edited by
                    @burnout426 said in Flash player does not work; can not be able.:
                    I've been messing with the extension API to make an extension to do what adding https://, http:// and file:///* does.
                    Test version of an Always Activate Flash extension
                    Goto opera://settings/contentExceptions#plugins and clear the Flash exceptions list if you want since it shouldn't be needed.
                    Download "always activate flash.zip", extract it, goto opera://extensions, click "Developer Mode", choose "load unpacked extension", pick the "always activate flash" folder and try some pages.
                    You can view the main.js and main.css files to see what's in them. Tweak main.css if needed and choose "reload" on the extensions page to test your modifications.
                      S 1 Reply Last reply
                      slytheringirl @burnout426 last edited by
                      @burnout426 Yes!! It works!! โœŒ Thank you! Thank you! Thank you! ๐Ÿ™‡ I've got flash back!! โ˜บ You should publish this in the extension store so those of us who can't get flash to work with the exceptions can get flash back.
                        burnout426 Volunteer @slytheringirl last edited by
                        @slytheringirl said in Flash player does not work; can not be able.:
                        Indeed. I want to see if I can find a better way to override Chromium's blocking of tiny Flash objects first though.
                          main.css in the extension is trying to work around these rules (the same-domain one at least) that Chromium has.
                            I updated my test extension to make the CSS better. From now on, I'll keep all info about it at https://www.reddit.com/r/operabrowser/wiki/opera/always_activate_flash
                              http://blogs.opera.com/desktop/2018/01/opera-51-0-2830-0-developer-update/
                              Opera added an option back to always load Flash. (See comments in post though.)
                                Opera 51.0.2830.0 developer update and flash work perfect here..
                                  zalex108 @burnout426 last edited by
                                  @burnout426
                                  Thanks anyway for efforts.
                                  ๐Ÿ˜‰
                                    @nvmjustagirl Awesome. Does the setting get reverted back to "ask" after you restart Opera though?
                                      Sorry to say .. Yes gets reverted back to "ask" after you restart Opera 51.0.2830.0 developer update..
                                        my guess devs intended this until ya did a restart for security.. umm lets ask developers lol
                                          @nvmjustagirl said in Flash player does not work; can not be able.:
                                          Could be. ๐Ÿ™‚
                                          I think it's code in Chromium that removes the setting as the setting isn't supposed to be used/supported anymore and the devs just have to force it somehow or remove the code that removes the setting.
                                            A Former User @burnout426 last edited by A Former User
                                            @burnout426 You prolly right.. but dev not gonna admit that, they will say intended this until ya do a restart for security ha ha ha *just kidding ๐Ÿ™‚
                                            ask dev die 'n to know !.lol
