    Same opera, same site, different visualization
    Future releases
    7603
      capcla last edited by
      I use opera developer on two different pcs. (same version) but the visualization of the site www.mediaworld.it is different. Why?
      Correct vilualizzation: https://ibb.co/hCffNv
      Wrong visualization: https://ibb.co/mots2v
        We do have an Italian forum, if you'd prefer. Click on the globe icon below to change languages. Also, I can see from the icon you're using Beta, not Developer.
        Don't recognize the OS, but it seems to be some version of Linux - knowing what might help here.
          Because on the Italian forum there is nobody
          Excuse me. I'm wronged. Like you have say, my opera is opera beta and not opera developer
          My operative systems are Debian Stretch (Stable) and Debian Buster (Testing)
            The image of correct one shows that ad-blocker is disabled while the wrong one has it enabled. So I would starting by disabling ad-blocker on that site.
              I think the problem is resolution. Set both the computers to the same resolution and see if the problems persists
                No. They are two different screens. The first have 19"; the second have 15.3". In any case, in windows, I have not this problems also with different resolution
                I have disable ad-block but the problem persist
                  Both computers use the same DPI?
                    I don't now. Anyhow, I have changed the resolution on the pc when the visualization is correct and the visualization continues to be correct.
                      I haven't had the page load incorrectly under either Windows or Mageia Linux ...
                        Did you visit this link https://www.mediaworld.it/mw/mediaworld-club or did you do only the login?
                        In the second case, after login, visit that page
                          I don't have a login for that site and don't plan to create one.
                            Ok, then you visit this link https://www.mediaworld.it/mw/mediaworld-club without login.
                            Is it well displayed?
                              Do you know if opera beta can displayed a site in mobile modality or in desktop modality?
                              If yes, how I can active/deactive this option?
                                As far as I know it's up to the site to send the desktop or the mobile version to the browser.
