    closing tabs resize problems
    Future releases
      axiba last edited by
      If I close more than one tab from right to left for a short time the other tabs are resized very small so that I can't see any tab. If the mouse pointer stays in tab-pane the tabs aren't resized to best size, they stay unclickable. If I move the cursor from tab pane, after 1 second the tab's get the best size.
      Anyone else the same problem?
      ©a-x-i
        donq last edited by
        Same here, dev 44.0.2505.0 (PGO). This is very annoying behavior (and actually all this tab animation is very annoying - pretty please to add setting to turn it off completely). Waiting for fix 🙂
          Known issue.
